JFK has this approach: https://aeronav.faa.gov/d-tpp/2006/00610COPTERR027.PDF
How is this approach said on frequency? Is it the "copter RNAV zero two seven approach" or the "copter RNAV zero two seven degree approach" or the "copter RNAV heading zero two seven approach" or something else?
    $\begingroup$ Ultimately, i don't think it really matters, as long as ATC can understand what you are saying. $\endgroup$ Jun 12, 2020 at 14:51
  • $\begingroup$ Degrees is never used on frequency. Could either be temperature or heading so you don't use it. Then the word heading is not required as the control knows what your talking about. The rule is keep it as short and clear as possible. So the first solution would be my answer. $\endgroup$
    – MaximEck
    Oct 2, 2020 at 14:16
Based on the 7110.65 2–1–17h, "degrees" is never used. Based on Note 9 under 4–8–1a, the text in paranthesis is omitted. So, ATC would say:
Cleared Copter RNAV zero two seven Approach
or
Cleared Copter RNAV heading zero two seven Approach
If you were requesting it, you'd say "Requesting Copter RNAV zero two seven approach."
However, since it is the only Copter approach at JFK, you could probably just request "the copter approach" and they'd know exactly what you're talking about. But ATC is required to use the phraseology as indicated in the Order linked above.
"Copter RNAV zero two seven approach"
    $\begingroup$ Could you add a source? That could also be personal experience with this approach or similar ones. In that case, could you add some more details? $\endgroup$
    – Bianfable
    Sep 2, 2020 at 14:04
