Do most airports (especially busy ones) use only one runway at a time for landing? For example, I know Heathrow uses only one of its runways at a time (although they might switch to another half way through the day).
2$\begingroup$ Half way through what? $\endgroup$ – Caius Jard May 26 '20 at 19:46
$\begingroup$ Does this answer your question? What determines in which direction a runway is used? $\endgroup$ – Pondlife May 27 '20 at 15:38
$\begingroup$ Many "busy" international airports (LAX, CDG, AMS,...) have more than 2 parallels runways. Even if using form landing only and another one for take off only, it would still allow the use of another runway. You should restrict your question to international airports with exactly 2 runways. $\endgroup$ – Manu H May 27 '20 at 17:22
2$\begingroup$ Statistically speaking, most airports only have one runway $\endgroup$ – expeditedescent May 27 '20 at 17:51
$\begingroup$ I just remember some international airport use parallel landings. SFO is a famous example. $\endgroup$ – Manu H May 27 '20 at 21:36
In general, any runway can be used for both takeoffs and landings. However, switching back and forth requires substantial safety margins. If you can use one runway for just takeoffs and another for just landings, efficiency goes up. If those runways are parallel, efficiency goes up again. This is why major airline hubs tend to have pairs of parallel runways.
Averaged over a day, the number of takeoffs and landings should be about the same, so the normal mode would be to split the runways as evenly as you can. If the number of runways isn't even, the last runway will often alternate throughout the day to mitigate short surges in one or the other.
As to which runways are used for what, the ones used for landing should be as far from each other as possible to maximize lateral separation of arriving traffic on instrument approaches. (Departing traffic mostly separates itself.) So, if you had four runways organized as two pairs, you'd expect the "inner" one of each pair to be used for takeoffs and the "outer" one of each pair for landings.
In the case of Heathrow specifically, runway usage is largely dictated by noise abatement agreements with nearby towns, rather than what makes the most sense operationally.
$\begingroup$ Depends on the airport and the traffic. For instance, at Reno (RNO) airlines and other large planes generally use 16R/34L, smaller planes use the parallel (and shorter) 16L/34R. However, it's not at all unusual for smaller planes to use 7/25 if there's no conflicting traffic. (Especially since crosswinds can sometimes be pretty strong on 16/34.) $\endgroup$ – jamesqf May 27 '20 at 4:08
$\begingroup$ I don't agree that "substantial safety margins" are required for runways with mixed departure and arrivals. Departing and arriving flights use roughly the same amount of time on the runway - typically around 45-60 seconds. You can do landing-takeoff-landing-takoff with 1 minutes between each flight just as well as you could do several takeoffs or landings each with one minute between $\endgroup$ – expeditedescent May 27 '20 at 17:56
$\begingroup$ @J. Hougaard: Though you need appropriate spacing/separation for wake turbulence. $\endgroup$ – jamesqf May 28 '20 at 5:28
$\begingroup$ @jamesqf There a mix of arrivals and departures is actually an advantage, since you will automatically have twice the spacing between consecutive departures and consecutive arrivals $\endgroup$ – expeditedescent May 28 '20 at 14:19
Airports will usually divide their active runways about evenly between takeoffs and landings. KATL (Atlanta Hartsfield Jackson) has 5 runways, and currently operates 2 for takeoff and 2 for landing. Most airports that can operate more than 2 runways simultaneously will use them all, unless the traffic is just very low.
Heathrow is exceptional in that it is one of the busiest airports in the world, and only has 2 runways.
$\begingroup$ Do you know where I can find information on how runways are assigned at each airport? For example, Beijing has 3 runways. I want to know whether two of them can be used simultaneously for landing. $\endgroup$ – Teodorism May 26 '20 at 20:14
$\begingroup$ How far apart are they? That is key - they need to be far enough that wing vortex from one landing aircraft doesn't impact the adjacent runway. I looked that up for the USA, if I recall 4300 feet was needed. $\endgroup$ – CrossRoads May 27 '20 at 0:15
1$\begingroup$ Heathrow has 2 strips and 4 runways as each strip has a runway in each direction. $\endgroup$ – GdD May 27 '20 at 8:18
1$\begingroup$ @GdD It's completely normal to refer to a strip as one runway although it can be used from either end. I don't think anyone is in doubt about what zymhan means by two runways. Claiming Heathrow has four runways would be misleading in most situations. $\endgroup$ – expeditedescent May 27 '20 at 18:00
1$\begingroup$ @Teodorism you can follow live ATC or flightradar24 during few hours to see actual assignation. $\endgroup$ – Manu H May 27 '20 at 21:38
