A rare -- as I was told -- situation of aborted take off for a large passenger jet. What is next?
Everything goes as smudge as possible after getting jetliner to full stop. Plane clears the runway and goes back to the either parking position or designated place at taxi way.
What steps must be performed in order to make this aircraft back to take-off waiting queue?
Approximately how long will it take for this plane to be taking-off again? I know that this vary on many circumstances that's why I am asking about approximate only. Is there any priority for the plane that should already went off? Will that take minutes, tens of minutes or hours?
Clarification: This question is for the sake of the story that I am writing. It (both story and the question) involves Boeing 777 taking off from LHR in August 2014.
Aborted take of is due to a misleading information coming from cargo doors' sensors that reveal a possible problem only during take-off, not before (i.e. during taxi). The doors are actually closed (no real danger posed after check). But there's a tiny piece of fabrics from cargo loader's uniform stick in between doors. This question is a follow-up or alternate version of this question. Here I'd like to know what happens, if such situation will be detected after V1 or shortly after take-off and thus after such aircraft returns safely to the airport and clears the runway. In linked question I am asking about the same situation detected before V1.
I am aware that most airline experts will say that such situation is not possible at all. I am, on the other hand, a system designer and I know that such "ghost" situations of "neither 0 nor 1" sometimes do happen. But, for the sake of this question, if you feel uncomfortable with such reason -- let's assume that take-off was aborted due to any other reason, i.e. engine failure. I belive that such reason has similar severity as the need of checking whether cargo doors are really closed due to fact that on-board computer provides misleading data.
I'd lilke to underline that this is purely hypothetical question. I am aware that while such questions are sometimes hard to answer, they're in general quite welcomed in this site and are not off-topic.
