What process do flight attendants and pilots follow to bid for routes and how does seniority play into this?
Is it the same across multiple airlines/does IATA have a preordained process that airlines are required to follow?
Sign up to join this communityWhat process do flight attendants and pilots follow to bid for routes and how does seniority play into this?
It totally depends on the airline and is different from one airline to another. There is no standard way of distributing schedules. Some of the ways that I have personally experienced or have seen it:
Almost all systems have some sort of giving the crew the option to at least bid for their desired off. Some other airlines just distribute the rosters randomly and then the crew will trade duties to get their desired flights and days-off, some have a system depends on the crew performance, there isn't really a standard way.
The ultimate target for airlines is to distribute flying hours among the crew equally, to avoid unnecessarily over-time costs and crew legality issues.
Typically, lines of flying are published, with a minimum "bid line guarantee" for the month. The company may have a minimum guarantee of 60 hours, for example, which is what's used for pay. The bid line might be 78 hours, meaning a pilot awarded that line would get 78 hours of pay, minimum. Pilots bid lines based on their own needs, pay, schedule, etc, and the bids are awarded by seniority. Upper seniority may get their first choice. Lower seniority may end up getting reserve lines or assigned to flying schedules that no one else wants.
