I was flying on my X-plane 11 flight simulator today and noticed something quite unsettling.
This was a VFR flight between KIAD and KDCA. I pulled up my map for reference and noticed I was flying orthogonal to the map's north direction, even though I was flying a heading of 100.
Juxtaposition: image showing heading indicator and map
The image shows the map and the PFD for your reference.
What is going on? Did I mess with some heading calibration setup? 100 degrees and 90 degrees are perfectly 10 degrees off, so I don't think this has to do with magnetic north issues.
P.S. Strangely, I got to my destination simply following the headings from ATC.
KIAD has a magnetic variation of 10 degrees west, and KDCA has a magnetic variation of 11 degrees west, so true vs. magnetic north actually makes sense.
  • $\begingroup$ I'm a little new to navigation.. I could benefit from it if you explain a little more, or redirect me to some answers which address this. I tried a search or two, but couldn't find much. $\endgroup$ May 18 '20 at 19:33
    $\begingroup$ @WilliamR.Ebenezer I have closed your question as a duplicate of another which will fully explain the difference between true and magnetic north. $\endgroup$
    – Jamiec
    May 18 '20 at 19:58
  • $\begingroup$ @Jamiec Thanks. $\endgroup$ May 19 '20 at 4:07
