I know that similar questions are available all over the internet, including this website. However, none of the answers make full sense to me.
I'm looking for simple answer (explain-like-I-am-5 type of answer). The vertical stabiliser has rudder. It provides yaw capablity to the aircraft and I understand that completely. However, people say that if a vertical stabiliser doesn't exist, it's very hard to control the airplane, it rolls the plane out of control if not monitored.
As far as I know, the roll can be controlled using ailerons. I've heard that all wing plane design is not suggested because of lack of vertical stabiliser(s). What exactly is it that the vertical stabiliser does?
    $\begingroup$ Hi sonofel. Please avoid asking multiple questions in one post. You should separate out your question about ailerons being used to control roll. $\endgroup$ May 18, 2020 at 12:18
    $\begingroup$ Sure @RyanMortensen, I've edited the question to focus on just one thing. $\endgroup$
    – sonofel
    May 18, 2020 at 12:22
    $\begingroup$ you should explicit what you don't understand in several similar questions so that we can understand what you don't understand and avoid writing a whole book about aerodynamics. $\endgroup$
    – Manu H
    May 18, 2020 at 12:56
    $\begingroup$ I suggest you read the part about yaw stability of how it flies and come back with details of what you don't understand. $\endgroup$
    – Manu H
    May 18, 2020 at 12:58
  • $\begingroup$ I read the question one more time; I now see you are saying you understand that the rudder yaws the aircraft. You aren't saying that you understand yaw stability. So, maybe my answer is somewhat relevant after all. Again, I have to emphasize that any discussion of the effect of the vertical fin on roll stability, which seems to be invited by your question, unfortunately has to be above the level of "explain it like I am 5"! $\endgroup$ May 18, 2020 at 14:53
The "vertical stabilizer" (or "vertical fin") provides what is known as "weathervane stability", "directional stability", or "yaw stability". It makes the plane act like a weathervane. A weathervane always points into the wind.
The wind a plane "feels" is not the external, meteorological wind, but rather the "wind" created by the plane's movement through the airmass (or perhaps we might prefer to say "within" the airmass). This apparent wind is called the "relative wind". So the vertical fin keeps the nose of the plane pointing in the direction that the plane is actually going, i.e. in the direction that the plane is moving through the air.
Imagine driving a car at high speed on an icy lake on a day with no wind. Can you see how a big vertical fin mounted at the back of the car would provide a "weathervane effect" that would tend to keep the car lined up with the direction it is actually moving, and would tend to prevent the car from "swapping ends" or sliding sideways?
That is what the vertical fin on an airplane does. It's a very bad thing if an aircraft "swaps ends" or slides sideways through the air at a very large sideslip angle. In extreme cases, there's essentially nothing the pilot can do to salvage the situation, and the plane may tumble violently out of control. It's a misconception to say that the function of the vertical fin or vertical stabilizer could be replaced by appropriate control inputs with the ailerons. It is true in many cases that planes with relatively small vertical fins often require the pilot to make larger rudder inputs to keep turns "coordinated", i.e. to keep the nose from swinging somewhat out of line with the direction the plane is going as it turns -- we'll save saying any more about that for some other answer.
Airplanes that lack a vertical fin must derive "weathervane stability" or "yaw stability" or "directional stability" from other aspects of the aircraft's configuration, generally having to do with the fact that more surface area is behind the center of gravity than in front of it. For example, a swept-wing configuration generates some amount of "weathervane stability" even without a vertical fin. Imagine putting a pair of swept wings or delta wings on a pole like a weathervane. Can you see how, as long as the pivot point were sufficiently forward, the whole assembly would tend to point into the wind like a weathervane? That's why hang gliders don't need vertical fins.
The question appears to contain a misconception about the relationship between yaw stability and roll stability. In fact, making the vertical fin too large actually tends to make a plane LESS roll-stable or MORE spirally unstable, so that it tends to roll away from wings-level into a steeper and steeper bank and turn. As a plane starts to roll into a turn, dihedral and sweep (if either are present) tend to generate a stabilizing roll torque that tend to roll the plane back towards wings-level, but only if the developing turn involves some amount of sideslip. In other words the roll-stabilizing effect of sweep or dihedral are only present if the plane is sideslipping to at least some small degree. A large vertical fin tends to prevent sideslip, and thus makes the plane behave as if it had less dihedral or sweep. That's why planes that need lots of roll stability, like "free-flight" model airplanes that must fly with no guidance of any kind from either a pilot or a computer, rarely have large vertical fins. Even though we don't want the plane to completely "swap ends" and tumble, or to slide sideways through the air at a really extreme sideslip angle, we do need for there to be some amount of sideslip in an uncommanded bank and turn in order for sweep or dihedral to be able to bring the plane back toward wings-level. Likewise when a free-flight model airplane is trimmed for an intentional turn, if the sideslip were somehow completely eliminated, we'd see the bank angle start to get steeper and steeper. If a pilot were actively controlling the airplane, he could deal with this by making an appropriate control input with the ailerons, but that option doesn't exist with the free-flight model airplane.
So other than preventing a violent tumble when the plane "swaps ends" completely, a vertical fin generally doesn't really contribute to roll stability.
  • $\begingroup$ Thank you for such a detailed answer! $\endgroup$
    – sonofel
    May 19, 2020 at 5:59
A good way to explain it is to have no wings at all, just use an arrow. The vertical stabilizer keeps the nose from yawing back and forth just as the horizontal stabilizer keeps the nose from pitching up and down while the arrow is in flight. This helps it fly straight and true with minimal drag. Roll is inconsequential until ... we add wings to our arrow.
Now any yaw (from a wind gust) creates a rolling "couple" as one wing goes faster than the other. Generally not a major issue with straight wings. Some dihedral takes care of that.
    older than 5 years, please continue reading
Then swept wings and much faster and larger aircraft came along. Swept wings increase yaw roll coupling by presenting an asymmetric straight half wing and more swept half wing to the airstream in addition to the rolling effect of wing speed asymmetry.
Designers countered by developing very large vertical fins, as seen on the Mig-15. These presented a whole new host of issues, as now the aircraft was highly asymmetrical to aerodynamic side forces. Planes of this design tended to spin out of control very easily.
In the rush to the jet age, the vertical symmetry of the biplane, and it's successor, the high wing monoplane was forgotten.
But, in addition to explaining to the 5 year olds, let them start building and flying for themselves. They will see how much vertical stabilizer and dihedral they need for their designs.
Shown here: Jenny's new "friend"
    – sonofel
    May 19, 2020 at 6:00
The vertical stabilizer is designed to provide a specific amount of passive weathervaning tendency. Not too much, not too little. The vertical stab's surface area is key to the airplane's behaviour for both lateral stability and spiral tendencies, and is tied into wing dihedral effect.
You want enough fin surface area to make the airplane passively respond reasonably quickly to yaw deviations, but not too much. Too little fin area, and its weathervane tendency is too weak and the airplane's nose wanders from side to side in turbulence.
If there is too much fin area, it weathervanes too quickly. If the airplane is put into a bank by a bump, for dihedral effect to work there has to be a bit of sideslip permitted to generate the self-righting force that dihedral is intended to create. So fin sizing is intended to allow a bit of lag between the sideslip starting and the weathervaning yaw response, so that dihedral effect can work to level the wings.
If the fin is too big, the weathervaning response is nearly instantaneous so that very little side slip is allowed to develop, and dihedral effect is less effective. So what happens is the airplane is disturbed by a bump and immediately yaws into the low wing and wants to start a descending spiral.
When airplanes are put on floats, the float surface area adds fin surface forward, which has the effect of making the existing fin smaller. The airplane is plenty stable laterally, but the nose wanders in bumps and needs more rudder work to do good coordinated turns (I've flown a Fleet 80 on floats, and it had no extra fin area added to the already smallish vertical fin with floats installed, and if you weren't on top of it with the foot work, it would slither around the sky like a glider would with no rudder inputs).
To fix this, either extra fin area is added at the tail when the floats are installed, or a trick that Cessna uses on later 180s and 185s can be employed, where a bungee spring is added to the rudder, which tends to hold it on center, and makes the rudder contribute some amount to the effective fin area. You have to live with higher rudder forces however.
  • $\begingroup$ Thank you for a detailed answer! $\endgroup$
    – sonofel
