Fighter
twinEngineSingleStabilozer
Hi, Could someone identify the fighter jet type and the Air Force it operates in? Thanks
Panavia Tornado, Royal Air Force (UK), 13 Squadron.
The aircraft in the question is identified as belonging to No. 13 Squadron by the distinctive green, yellow and black 'Squadron flash' painted on the aircraft side below the front part of the cockpit.
Royal Air Force roundel
13 Squadron flash
A Tornado of No. 13 Squadron as seen at the 2007 CIAF air show in the Czech Republic
Above: a Tornado of No. 13 Squadron as seen at the 2007 CIAF air show in the Czech Republic. The squadron flew Tornado GR.1A aircraft from 1990, and later the GR.4 and GR.4A variants.
Here is ZA401 (a GR.4) at RAF Leuchars in 2005 with the 13 Sqn flash painted on the tail as well as the normal place, as part of the Squadron's 90th anniversary celebrations:
No. 13 Squadron RAF (Wikipedia)
  • $\begingroup$ Many squadrons have used this plane (9, 14, 15, 16, 17, 20, 27, 31, 45, 75, 617), but are you sure about 13? It seems to be one of the few that hasn’t? $\endgroup$ – Tim May 16 '20 at 17:26
    $\begingroup$ @Tim - 13 Sqn operated Tornados from 1990 to 2011, first from Honington and then in 1994 moved to Marham. $\endgroup$ – Michael Harvey May 16 '20 at 18:24
  • $\begingroup$ I never liked them much when they were in service, but now they are gone, I feel a bit nostalgic about Tornados. I think ZA401 looks nice above. $\endgroup$ – Michael Harvey May 16 '20 at 18:29
  • $\begingroup$ ahh so they did. Strange the page on the Tornado misses that off. I wonder if it’s because of the disbanding / reformation $\endgroup$ – Tim May 16 '20 at 18:29
That is a Panvia Tornado operated by the UK Royal Air Force.
You can tell by the shape of the nose wheel door, and the rear of it has a characteristic boxy shape with the stabilators lower than the wing. The roundel is the RAF low visibility roundel.
    $\begingroup$ The shape of the nose is characteristic. $\endgroup$ – Michael Harvey May 16 '20 at 8:06
  • $\begingroup$ @MichaelHarvey characteristic of the Tornado IDS, bomber-striker, while the Tornado ADV interceptor had a longer nose. $\endgroup$ – EarlGrey May 17 '20 at 19:12
  • $\begingroup$ @MichaelHarvey why is it’s nose so pointy? It’ll poke somebody’s eye out! $\endgroup$ – Dai May 17 '20 at 19:49
  • $\begingroup$ You can also narrow it down by being twin-engine and flown by the RAF. The other twin-engine options are the Canberra, Lightning, Buccaneer or Typhoon, all of which have very distinctive shapes which this clearly is not. $\endgroup$ – Graham May 17 '20 at 22:15
