Using the Area ratio (A/A*) and for the desired exit Mach number I have designed a cd nozzle. The Inlet total pressure (Po) and the total temperature (To) is calculated using Isentropic relations for the optimum condition.
FLUENT CONDITIONS:
Solver type: Density-based, Absolute, 2d, Axisymmetric
Model: Energy On, Inviscid
Material: Air (Ideal gas)
Boundary condition: Inlet- Pressure inlet- 792812.3356 Pa; Supersonic/Initial Gauge pressure: 790000 Pa; Total Temperature: 518.4 K
Outlet- Pressure outlet- 101325 Pa; Backflow total temperature: 288 K
Operating condition- 0 Pa
For this condition, I should get an ideal flow throughout the nozzle, but there's an oblique shock inside the cd nozzle. Is this a design flaw or any error in the ANSYS fluent conditions?
How to avoid Oblique shock inside CD nozzle?
Geometry
Mach contour
Pressure contour
