I have a problem that it gives us the MTOW of a UAV (200 kg), the speed and the reference area. So its probably easy to find the CL knowing that it flights at steady level flight (L = W). I'm confused about the use of MTOW. Should we multiply it by the g? (gravity acceleration)
I've done some exercises in the past using lbs as the unit of MTOW and we didnt multiply it with the g. (John Anderson. Aicraft performance and design) Is it different when using lbs and kgs? I'm confused with the different metric/imperial systems.
