Cessna 172 has weight about 1 ton and it's engine produces about 213 Kg of thrust, and it flies great.
So if I make a plane with a weight of 100kg including pilot and fuel so will 15 kg thrust good for the plane, and if not please recommend me engine which is perfect and please also recommend me the best prop size.
What is thrust to weight ratio of Airplanes. Sorry for bad English. thanks
