As I understand it, the gliding range is given by a lift to drag ratio—hence to increase the gliding range, I would want to increase the lift and reduce the drag as much as possible.
To that end, apparently, it seems that high AR fits both the bills. However, does that mean that I will not able to enhance the gliding range with low AR wings at all?
  • $\begingroup$ Sure you can. Shave off some of the wing chord to make them into higher aspect wings. The increase in wing loading won't decrease your gliding range in still air, and it will actually increase the gliding range if you are gliding into a strong headwind. Also, make like hawk and get some slotted wingtips, ideally ones you can close at will when you need to fly fast. $\endgroup$ May 2, 2020 at 13:49
  • $\begingroup$ Highly related (if not a dupe): Relation between drag and aspect ratio $\endgroup$
    – Manu H
    May 2, 2020 at 17:50
    $\begingroup$ Does this answer your question? What dictates the aspect ratio of an aircraft's wing? $\endgroup$
    – Manu H
    May 2, 2020 at 17:51
With a given wing span, everything that reduces drag will increase the gliding range. Aspect ratio is less of a factor here because induced drag depends on wing span, not aspect ratio. But increasing the aspect ratio with a given wing span will reduce the wetted surface and, consequently, friction drag.
What can be done to increase gliding range outside of increasing span?
Generally, a low aspect ratio shifts the polar point of best gliding range to lower lift coefficients, so reducing all that parasitic drag becomes more important the stubbier the wings are.
The most effective way, however, to increase gliding range is indeed a larger wing span if all other parameters are held constant. Increasing span while keeping wing area constant will:
  • increase aspect ratio and reduce wing chord,
  • reduce induced drag at the same lift coefficient,
  • and, as a consequence, lower the optimum gliding speed, so the parasitic drag is lower as well.
  • $\begingroup$ I think you should describe the effect of low and high aspect for the same wing area. $\endgroup$
    May 2, 2020 at 21:41
  • $\begingroup$ @JohnK it has already been done in this answer $\endgroup$
    – Manu H
    May 3, 2020 at 7:23
  • $\begingroup$ No that answer also talks about different ARs with the same span, so one has less area than the other. I'm talking about two wings of the same area, say because I want to consider two cases with the same wing loading in order to have the same stall speed. A 1-26 has 160 sqf and 1-23 has 165 sqf, more or less the same, AR of 10 and 17 respectively. L/D of 23 and 31 respectively. For two wings of the same area, the higher AR does better even tho wetted area is the same. I believe the answer is related to lower tip losses and the higher AR is moving a larger package of air a smaller amount. $\endgroup$
    May 3, 2020 at 12:50
  • $\begingroup$ @JohnK: The higher AR does better because wingspan is larger. 16 m versus 12.2 m - that is about the ratio if their respective L/Ds, too. $\endgroup$ May 4, 2020 at 5:33
