I know there are very well kept records for death and accident rates in GA aircraft, but I was wondering if there were numbers for para-motor aircaft that are easy to compare?
  • $\begingroup$ What kind of statistics are you interested in? accident per flight? accident per flight hour? accident by distance covered? absolute accident number? all of them? $\endgroup$
    – Manu H
    Apr 28, 2020 at 20:27
In the US, there are no records kept nationally, because they fly under FAR Part 103, and are, for the most part, unregulated. Neither para-motors themselves, nor their pilots are required to be certified. Para-motors are not required to be registered. In fact, there is no actual government regulation requiring training of any kind to fly a para-motor. It is recommended, but not actually required.
There is no requirement to report accidents to any governing body, beyond those of the organization (flying club) the pilot may belong to.
Pilot certification -
At this time, however, pilots of ultralight vehicles are not required by Federal regulation to be certificated.
Aircraft Certification -
However, the FAA presently has no intent to require certification of these vehicles by Federal regulation.
Aircraft Registration -
However, registration of ultralight vehicles will not be required by Federal regulation at this time.
  • $\begingroup$ You are correct. Class E is controlled not the same as Class G. You are not, however, required to report in to anyone in either G or E. Just that while in E you must have visibility of 3 miles. My bad, and it was incorrect information. I have simply removed it. It's not really relevant to the question asked. Up- or Down-vote as you wish. My gist was that since neither the pilots nor the aircraft are required to be registered, it would be difficult to maintain records of accidents. $\endgroup$
    – CGCampbell
    Apr 29, 2020 at 21:31
