Yes and no, but mostly yes, especially the Kamov family.
Here's a picture(Wikipedia, CC-SA) that shows the (pair of very complex) flapping mechanism on Ka-27. Even though two rotors together should be able to balance out the asymmetric lift, the rotor hub and rotor for each individual rotor isn't rigid or strong enough for handle its own asymmetry (when it happens accidentally, e.g. the receding blade stalled, the receding blade of the top rotor will bend down and hit the advancing edge of the bottom rotor bending up and cause a catastrophic failure, e.g. Ka-50 had a series of rotor collision accidents).
However, there are rigid rotor helicopters and these don't bend nearly as much and don't need to flap, but none of them are among the Kamov lineage.
This is especially useful for high speed helicopters (e.g. Sikorsky S-97 Raider) because no amount of flapping will generate enough lift before stalling to cancel out the lift asymmetry, for the receding edge is too slow, so it has to let each rotor remain asymmetric and let the two rotors cancel each other.
