I was watching videos of F35B taking off and landing vertically on ships when I realized that when transitioning from horizontal to vertical flight mode (I don't know the exact vocabulary to describe that), the horizontal elevator moves to "stick pushed full forward" position. The elevator is also put in that unusual position when transitioning from taxiing to a vertical takeoff. I know that the elevator position is not significant in vertical flight as attitude is controlled via non-aerodynamics means. Thus I wonder why this control surface is then put in that position for that flight phase instead of staying in its previous position or in more neutral position.
I'm even more confused as this behaviors doesn't seems to be reproduced on the AV-8B nor on the Yak-141.
  • $\begingroup$ I'm not sure precisely why it does this, but, I agree with you that it's not because of pitching moment - see my comment to Camille Goudeseune's answer. Fig 1 in this paper might help - ltces.dem.ist.utl.pt/lxlaser/lxlaser2016/finalworks2016/papers/…. It gives you the airflow pattern around a hovering F-35. $\endgroup$ – Anonymous Person Apr 28 at 16:26
  • $\begingroup$ I have a few theories, one possibility is that the elevator position increases the gap between the trailing edge of the wing and the leading edge of the elevator, giving more space for the exhaust to "suck" air downwards through that gap with it, might cool the exhaust a little and add a little airflow (and thrust). Or it could be to let the fountain upwash escape and not burn the jet. IDK, these are just my guesses, hopefully someone who worked on the F-35 will answer. $\endgroup$ – Anonymous Person Apr 28 at 16:29
-1
Vertical flight needs the big panel behind the canopy open, to admit air to the LiftFan® that it otherwise covers. While that's open, in the transition to horizontal forward flight it would pitch the nose up. The deflected elevators might compensate for that, although the downward-vectored thrust at the rear of the airplane compensates more effectively during slow forward flight (as shown in the video in Anonymous Person's comment.)
The AV-8B lacks such a speed-brake-like protrusion, so it needs no elevator deflection to compensate.
The Yak-141 has what looks like a smaller panel. Photos of it hovering show no elevator deflection, but the far-aft flaps are strongly deflected, perhaps for the same purpose.
| improve this answer | |
  • $\begingroup$ I think you are wrong as in this video we can clearly see that the liftfan doors opens several seconds before elevators deflection, while the speed is the same (the aircraft is not moving at all and on the ground) $\endgroup$ – Manu H Apr 28 at 6:58
  • $\begingroup$ This is probably not the case, because in this video (youtube.com/watch?v=vsKwBzt7rDY), at the 2:12 mark, you can see the F-35 flying around, pretty fast, with the liftfan cover fully open, without much elevator deflection. $\endgroup$ – Anonymous Person Apr 28 at 16:13
  • $\begingroup$ @AnonymousPerson nice video! it clearly shows that when the liftfan doors are open, the elevator deflection is more pronounced at low speed (e.i. when aerodynamic controls are not needed). $\endgroup$ – Manu H Apr 30 at 7:12
