Are there any aircraft with a 4-wheel nose landing gear and a 16-wheel main landing gear? I need this to answer my review of an aircraft design project.
20$\begingroup$ I'm curious. How will finding such an aircraft help with a review of some other design? $\endgroup$ – CatchAsCatchCan Apr 25 '20 at 10:27
5$\begingroup$ @CatchAsCatchCan "If they did it so can we!" :) $\endgroup$ – DeepSpace Apr 25 '20 at 21:28
The Il-76:
4 main bogies with 4 wheels each, nose gear with 4 wheels.
this one has a better view of the wheels, but it's a CGI:
4-wheel nose gear is rare, 16-wheel mains are more common: Boeing 747 (4 trucks with 4 wheels each in 2x2 config), Avro Vulcan (main trucks with 2 axles with 4 wheels each), HP Victor (same as Vulcan), Shorts Belfast (same as Vulcan).
The Antonov AN-124 has 4 nose wheels and 20 mains which is close to that configuration.
The Antonov AN-225 is also close to being configured this way. It has 4 nose wheels but has 32 mains.
(source)
5$\begingroup$ That is one MASSIVE #@$§¥& airplane! Just, dang! $\endgroup$ – Ralph J Apr 24 '20 at 23:02
2$\begingroup$ C-5 has 4 front and 24 mains, but can be misconstrued as 16 from some angles. $\endgroup$ – Moo Apr 25 '20 at 6:48
7$\begingroup$ I can only count 28 main wheels for AN-225 on that picture. $\endgroup$ – Alex Apr 25 '20 at 7:03
$\begingroup$ Can't find a good picture of the landing gear, but the Stratolaunch looks like it has either 24 or 48 main wheels, and 4 or 8 nose wheels. $\endgroup$ – jamesqf Apr 25 '20 at 16:19
I'd like to mention the Lockheed C-5 Galaxy, which has 4 nose wheels and 24 mains.
[source]
The large Antonovs use two two-wheel bogies for their nose gear, whereas the C-5 uses one four-wheel bogey. For the mains, the Antonovs have multiple inline two-wheel bogies, whereas the C-5 has four six-wheel bogies. As Moo commented while I was writing this, those distinctive six-wheel bogies can be deceptive from some angles and give the appearance of 16 main wheels.
4$\begingroup$ A tricycle undercarriage, where the main gear comprises four tricycle undercarriages... $\endgroup$ – Level River St Apr 26 '20 at 11:43
