How many cabin crews are needed for an A350-1000?
    $\begingroup$ crews, one, as always. are you asking about crew members? $\endgroup$
    – Federico
    Commented Apr 19, 2020 at 15:16
It depends where you are flying, i.e. which countries rules apply. In the US for example, the minimum cabin crew is determined by the seating capacity:
For airplanes having a seating capacity of more than 100 passengers—two flight attendants plus one additional flight attendant for each unit (or part of a unit) of 50 passenger seats above a seating capacity of 100 passengers.
(CFR 121.391 (a) (4))
The A350-1000 can seat up to 480 passengers, which would then require 10 flight attendants. Typical seating is however only 369 according to Wikipedia, which would only require 8 flight attendants.
In Europe, EASA defines the minimum number of cabin crew in the Type Certificate Data Sheet (TCDS):
For the A350-1000, the minimum required cabin crew number established during the aircraft certification process is 8, irrespective of the Maximum Operational Passenger Seating Capacity (MOPSC).
In accordance with the operational requirement ORO.CC.100-Number and composition of cabin crew, if the MOPSC for the specific aircraft exceeds 400, the minimum required cabin crew number becomes 9.
(EASA A350 TCDS)
So here 8 or 9 flight attendants are required, also depending on the seating capacity.
  • $\begingroup$ WOW thank you very much $\endgroup$ Commented Apr 19, 2020 at 13:56
    $\begingroup$ Hello @MohammadGohardoust: Instead of thank you comments, consider pressing the upvote button (⯅) for usefulness, and the check mark (✓) for helping solving the issue. $\endgroup$
    – user14897
    Commented Apr 19, 2020 at 14:43
  • $\begingroup$ What about the A350-900? Also most airlines put more flight attendants in because of the different classes. Sure by law it may be by capacity, but in an airline's perspective, that's not the case. $\endgroup$ Commented Apr 19, 2020 at 14:46
  • $\begingroup$ @AirCanada001 Typical seating for the -900 is 315, so 7 flight attendants would be enough in the US, but EASA still requires 8: "For the A350-900, the minimum required cabin crew number established during the aircraft certification process is 8 (2 per exit pair)". Of course airlines can use more flight attendants, these are just the minimums for safety reasons, especially during an emergency evacuation. $\endgroup$
    – Bianfable
    Commented Apr 19, 2020 at 15:42
  • $\begingroup$ @Bianfable: OK, thank's for the answer, you provided much more clarity. $\endgroup$ Commented Apr 19, 2020 at 19:29
