How do I know in what way I should read a number off the naviagtion computer scale on the slide rule side?
Eg. 241 and 24.1
Sign up to join this communityIf you are talking about an E6B, you follow the same rules for your result as you followed for your inputs. If you used a factor of 10 for your inputs, you use a factor of 10 for your results. If all else fails, you use the common sense rule. For your particular calculations, does 241 make sense? Or, does 24.1 make sense?
