I was just informed that the world's biggest aircraft was the Antonov An-225, and huge airplane.
That being said, I was curious what the world's biggest military aircraft was. Are there limitations such as maximum speed etc,.?
  • 9
    $\begingroup$ Biggest payload, gross takeoff weight, wingspan, length, etc, or some combination of those? $\endgroup$ – Camille Goudeseune Apr 15 at 21:11
  • $\begingroup$ Also current military, ex-military converted to civilian use (the An-225) or historic (perhaps the Hughs "Spruce Goose"). And by wingspan, the Stratolaunch carrier aircraft is the largest flying plane. $\endgroup$ – jamesqf Apr 16 at 4:19
    $\begingroup$ Actually, I think the military zeppelins were way way larger than any airplanes of all time. $\endgroup$ – user3528438 Apr 16 at 12:41
-5
The world's biggest military aircraft is the Lockeed Martin C-5M Super Galaxy, a military transport plane which can carry a payload of up to 129,274 kg.
An F-35 after getting addicted to fuel
This is what happens after an f-35 drinks wayyyyy to much fuel
Now the biggest fighter aircraft, however, is the Tupolev Tu-28.
Specs:
Length:75.53 meters
Top speed: 855 km/h
Wingspan: 68 m
Range: 12,964 km
Cruise speed: 919 km/h
| improve this answer | |
    $\begingroup$ An-124 is bigger and heavier than Galaxy, and it is a military transport. Arguably, even An-225 is. $\endgroup$ – Zeus Apr 16 at 1:05
    $\begingroup$ @Zeus No, it’s not. The C-5M is dimensionally larger and has a MTOW about 40,000 lbs greater than the AN-124. $\endgroup$ – Carlo Felicione Apr 16 at 5:34
    $\begingroup$ @Zeus The An-225 was never a military transport, nor was it designed to be one. $\endgroup$ – Ron Beyer Apr 16 at 13:11
    $\begingroup$ @Ron, in Soviet Russia, you can never tell. An-225 was designed to carry Buran, which was largely a military program. Furthermore, it is essentially a stretched An-124, which is 100% military and was made to military standards and requirements. $\endgroup$ – Zeus Apr 17 at 0:32
    $\begingroup$ The cruise speed can't be better than the top speed!!! $\endgroup$ – L'aviateur Apr 17 at 8:41
Because the AN-225 is not a military aircraft and Zeppelin will be winner, there is no one biggest plane.
  • C5 Galaxy = 76 meters long, 68 m wingspan, 20 m high, wing area:576 m2
  • An-124 = 69 meters long, 73 m wingspan, 21 m high, wing area: 628 m2
  • (Bonus:) Hughes H-4 Hercules (Spruce Goose on picture) = 66.55 meters long, 97,54 wingspan, 24 m high, wing area: 1 061,8 m2
See this : comparison
Source:https://fr.m.wikipedia.org/wiki/Hughes_H-4_Hercules#/media/Fichier%3AGiant_planes_comparison.svg
    $\begingroup$ Not quite sure why this got a down vote. It seems to accurately point out that "biggest" depends on what dimension one measures... Except, of course, that it's trying to answer an unclear question. $\endgroup$ – FreeMan Apr 16 at 14:55
    $\begingroup$ ... and then there's the issue of volume, which some would also consider a measure of "big". $\endgroup$ – Michael Tracy Apr 16 at 15:46
  • $\begingroup$ @Michael Tracy: And also gross weight, or cargo capacity. $\endgroup$ – jamesqf Apr 16 at 19:23
