B737-300 FMCs ARE OF SMITH INDUSTRIES 2907a4/10-6225-003
    $\begingroup$ You should explicit technical terms you use. Although the community here is expert in aviation, this field is huge and no one can be expert in all subfields. Thus you may at least provide links to explain all references. $\endgroup$ – Manu H Apr 14 at 11:23
It wouldn't work. The two FMC's need to communicate & stay in sync; that process requires the same OFP in both.
| improve this answer | |
