To calculate the V approach the FMS is using a wind either taken by the ADIRS or inserted on APPR PERF page. At first I will say that it takes the wind inserted by the crew, but I am not completed sure about this assumption since the MINI FUNCTION on A320 will need as well wind info taken by ADIRS to be able to cope with sudden loss of headwind / increase tailwind.
It uses the wind entered in the PERF APPR page to correct the computed VAPP:
Takeoff, performance and go around speeds
The FMGC uses the performance model and either the predicted landing weight or the current gross weight at transition to the approach phase to compute approach speeds (VLS, VAPP, F, S, Green Dot). On the PERF APPR page, the selected LDG CONF determines the applicable VLS and VAPP, the latter being updated by the WIND correction that the pilot enters on the same page.
(A320 FCOM - Autoflight - Flight Management - Performance, emphasis mine)
  • $\begingroup$ I'm a bit disappointed. I imagined the aircraft was able to evaluate wind component based on difference between trajectory as defined by inertial sensors and trajectory as expected by air mass sensors (static and dynamic pressure, AoA, side slip sensor,...) $\endgroup$
    – Manu H
    Apr 10, 2020 at 7:49
    $\begingroup$ @ManuH The aircraft is capable of doing exactly that and it will display this wind component on the ND (Navigation Display). You don't want to use this current and local wind for VAPP though, because this should be based on the wind on the ground at the airport, which you can only know in advance from the ATIS. If you slow down to VAPP at 1000ft you still have very different wind as measured by the aircraft compared to ground level. $\endgroup$
    – Bianfable
    Apr 10, 2020 at 8:45
The approach speed that is shown on the MCDU performance page is based on the pilot entered wind or in Airbus terms, tower head wind component. The headwind component is the one which affects the aircraft energy on the approach.
The approach speed also known as Vapp is calculated as follows:
Vls (lowest selectable speed or Vref in landing config) + 5 knots (for autothrust) + 1/3 headwind component (limited to a maximum of 15 knots).
The ground speed mini (GS mini) function uses this calculated Vapp as a minimum approach speed to vary the approach speed with changes in headwind component. And yes, you are absolutely correct. The live wind direction and speed data is fed to the FMGC by the ADIRS. From this data, instantaneous headwind is computed by the computers and the approach speed on the speed tape is varied. The autothrust then adds or reduce thrust to keep the target speed. The GS mini uses the aircraft inertia to vary the approach speed. For example, if there is an increase in headwind, because of inertia, the aircraft tries to increase its indicated air speed to prevent a reduction in ground speed. This change in speed then becomes the new Vapp and thrust is added to maintain the Vapp. The idea behind the GS mini is to conserve the aircraft energy. If there is a headwind and if it suddenly dies out, the speed reduces and a thrust increase is required to keep the speed from going close to the stall speed of the aircraft (Vref is just 1.23 x stall speed in landing config). When Vapp is increased with an increased headwind component, even when the wind speed goes down, the aircraft is maintained at a high energy state. The target speed then is changed to a lower value and thrust is reduced to match the new wind conditions. It is a very interesting sight to see the aircraft Vapp target moving on the speed scale of the PFD on the approach. This is very noticeable in windy approaches.
In a conventional aircraft, when we fly gusty approaches, we add about 10 knots to our Vref, in order to compensate for any reductions in wind speed. The GS mini is a more accurate version of this as it varies approach speed based on the actual prevailing winds. For GS mini to be active, the pilots must use managed approach speeds and autothrust must be engaged.
