So, to be more clear I currently have an assignment about the Boeing 737-800.
I have to find out the total takeoff distance of the aircraft. I'm using Anderson's book " Aircraft Performance and Design" and I'm quoting that a turbofan engine is affected from the velocity of the aircraft.
Anderson uses this equation: T = k1 - k2*V + k3*(V^2) where k1,2,3 are constants from engine to engine. At his example he uses a Gulfstream IV aircraft and takes the constants as below (chapter 6, example 6.6):
The constants are selected for the takeoff phase. I guess that these values come from the manufacturer but I cant find this type of info anywhere. Not even a number about the takeoff thrust. The only thing that I can find is the maximum takeoff thrust which is the max thrust available from the engines.
1$\begingroup$ Please look into Type Certificate DataSheet of variants you interested. $\endgroup$– vasin1987Apr 5, 2020 at 9:06
$\begingroup$ Given a set of environment conditions: get Vr and Takeoff distance (at TOGA) for three different GW from B737 manuals; then solve a system of linear equations. Those 3 constants are not published and probably Safran's engine model is more complex anyway... $\endgroup$– AfeApr 5, 2020 at 10:28
1 Answer
Developing 21,600 to 33,000 pounds of takeoff thrust, the CFM56-5B is the only engine that can power every model in the Airbus A320ceo family.
