Front View of Triplane with a Dihedral middle wing
I wonder if a triplane glider whose front view is shown in the figure can be built and flown successfully. As you can see, the middle wing has a dihedral angle, but the top and bottom wings do not. The vertical lines represent structural members. The idea behind this strange design is that a box-shape with diagonal members is structurally very strong, hence my interest. I realize that the structural members at each end will contribute to the drag, even if they have a streamlined shape. I also realize that every corner of this shape will not produce much lift, but will produce much interference drag. Yet, I wonder if this weird triplane will fly properly at low speeds. Any thoughts?
    $\begingroup$ "Whose front view is shown in the figure" What figure? - Nevermind, seems imgur is having issues this afternoon. $\endgroup$
    – Ron Beyer
    Apr 1, 2020 at 19:34
    $\begingroup$ Probably is flyable... do you intend a tail? Or swept wings? Or... ? $\endgroup$ Apr 1, 2020 at 19:36
It would depend on the relationship between span and separation. The dihedral would be too great on a short-span wing, as drawn, leading to all sorts of issues. Since the separation needs to be more than usual, approaching two chord lengths, you would need a very high aspect ratio, maybe 15 or so.
But if you were to leave out the middle wing and cross-brace each side with thin wires, as a biplane it would be just as stiff and perform a heck of a lot better.
This might work better thinking on the x,y, and z axes. I am seeing a dihedral upper wing, a straight lower wing, and a t-tail.
A dihedralled upper wing, with a little sweep, would interfere with the lower wing first near the front, causing the plane to pitch down before it stalled if AOA became too great. There should be some gap between the two.
The concept, as drawn, would suffer from interference issues, and, as the other writer explained, would work far better with bracing wires, better still with 2 or (or 1) thick cambered cantilevered wings.enter image description here
Also possible would be a "Sopwith Bonanza": a biplane with a butterfly tail.
