1 Answer
The "canoe" is thought to house "advanced" satellite communications equipment. This is a classified aircraft though, so there isn't a lot of publicly available information on exactly what other equipment might be contained in that hump.
$\begingroup$ This angle makes that a shockingly unaerodynamic looking hump! It looks like the front is very vertical and not at all smoothly blended into the roof line. Of course, that's topic for a different question, and considering the classified nature of the aircraft, probably an unanswerable one, so I won't bother asking $\endgroup$– FreeManApr 1, 2020 at 13:58
$\begingroup$ @FreeMan Side-on angles may be deceiving. It looks like the front is tapered to cause less drag so it probably isn't a huge impact. It doesn't seem to matter though, the aircraft can stay airborne indefinitely because there seems to be a refueling probe on the nose. $\endgroup$ Apr 1, 2020 at 14:15
$\begingroup$ Good thing about refuling, too, @RonBeyer - those look like very inefficient low-bypass engines!
</OT ramblings>
$\endgroup$– FreeManApr 1, 2020 at 14:23
