The formula in Prouty's book shows
  • the blade inertia unit is slung-feet squared
  • rotor kinetic energy unit is foot-pounds
if blade's inertia is high, the rotor kinetic energy should be high.
In other words, blade inertia and rotor kinetic energy are two different terms for the same thing.
am I right?
  • $\begingroup$ The term "inertia" is used to mean several different things: mass, momentum and moment of inertia. Without more context, I can't tell which meaning is intended in the formula you don't quote. However, none of these things is the same as the kinetic energy, as you can see immediately from the different units. $\endgroup$ – David Richerby Jul 8 '14 at 7:32
  • $\begingroup$ How is it unclear what he was asking? Emil answered pretty accurately. $\endgroup$ – Koyovis Jun 15 '17 at 1:41
Blade inertia and rotor kinetic energy are NOT the same thing, but they are related.
Blade inertia is a characteristic of the blade. It is a quantity that shows how difficult it is to change the blade speed (either by acceleration or deceleration) The bigger the inertia of the blade, the harder it is to make it move or make it stop once it's moving. It has nothing to do with the speed/RPM of the blade, it has the same value regardless if the rotor is turning or not. It depends on the way the blade is built (how heavy it is and how is its weight distributed).
Rotor kinetic energy depends on inertia AND rotor speed (RPM). So, a rotor when it's stopped has inertia but has no kinetic energy.
Once you start turning the rotor you start building kinetic energy in it using power from the engine. If rotor inertia is big, the engine will work harder to accelerate the rotor BUT, if the engine fails in flight the bigger inertia will oppose RPM decay giving the pilot more time to perform the proper actions.
