Can you guys help me find airports with these approaches:
- An airport with only an LNAV mins (so no LNAV/VNAV or anything other than just LNAV)
- One with an LPV lower than 200 feet
- One with an ASR approach. And what is an ASR approach?
Sign up to join this communityCan you guys help me find airports with these approaches:
All ASR and PAR approaches are listed in the current Terminal Procedures Packet.
They are not listed with the other approaches but in the front matter after the alternate airport section. I have never seen a PAR approach not associated with a military airport. There are joint use military/civilian airports that have PAR approaches and allow civilians to fly them.
An ASR approach is an Approach Surveillance Radar style approach. The guys on MZeroA.com flew one in this video at KLAN. They are not "at" any airport nor are there plates for them it is effectively a function of ATC. I have heard them flown at a few "smaller" class D facilities near me for practice. Generally to practice them you need to be somewhere that ATC does not mind clogging the radio up as they take a fair bit of radio work to fly.
The RNAV (GPS) RW1 into KWWD has only LNAV minimums. (Note: It also has circling minimums which most LNAV airports will have unless terrain or some other issue forbids a circling maneuver).
As far as I know there are no LPV approaches that take you lower than 200 feet as is regulated by the FAA:
Localizer Performance with Vertical Guidance (LPV). An RNAV function requiring WAAS, using a final approach segment (FAS) data block, which computes, displays and provides both horizontal and approved vertical approach navigation to minimums as low as 200 foot ceiling and ½ mile visibility.
