15
The Kuznetsov NK-12 is a Soviet turboprop engine of the 1950s, designed by the Kuznetsov design bureau. The NK-12 drives two large four-bladed contra-rotating propellers, 5.6 m (18 ft) diameter (NK-12MA), and 6.2 m (20 ft) diameter (NK-12MV). It is the most powerful turboprop engine to enter service. (Wikipedia: Kuznetsov NK-12)
Tupolev TU-95 (NATO codename Bear) and Antonov AN-22 (NATO codename Cock) use the NK-12 turboprop engine, and as can easily be seen in many videos available on the internet, their propellers are not geared in a way that would make them turn in equal rpm.
TU-95 propellers turning ratio is such, that for each full turn of the front propeller, the one behind turns a little more than half a turn: TU-95 engine start on Youtube.
The two frames above show the aft propeller's lag after the forward propeller moved a quarter-turn.
For AN-22 the ratio is one full turn for front prop, and about 3/4 for the rear one: AN-22 engine start on Youtube.
Why such ratios? What is the reason the front propeller has significantly higher rpm compared to the one behind it? The air that has gone through the disk of the first propeller has obviously been accelerated, and has gained a swirl momentum. This would have to be taken into consideration somehow.
My own guess would be that this has to do with the aforementioned flow changes, load distribution between propellers, and/or something with vibrations and resonances of the powertrain.
Please do not hesitate to prove me wrong on this one, but for that to fly, I'd require some hard evidence concerning the NK-12 powertrain.
  • $\begingroup$ Can you link the document showing the gear ratios? $\endgroup$ Feb 22, 2020 at 0:03
  • $\begingroup$ I do not have such documentation, the differing rotational speeds can be seen in the videos I've linked into the question. The AN-22 video is of a very good quality and shows the start of two engines, with the same ratio of propeller rpm on both. I'm sure there is documentation available, but most likely it is in russian, and that's a problem for me... $\endgroup$
    – Jpe61
    Feb 22, 2020 at 0:18
  • $\begingroup$ Ok, so you are basing this opinion of gear ratio solely on the videos, well, what if it's driven by separate turbines or a freewheeling planetary? $\endgroup$ Feb 22, 2020 at 0:25
    $\begingroup$ You have 1 power input (from the turbine) and 2 power outputs you are splitting power to. That's 3 things, and planetaries are really good at splitting power amongst 3 things. You just need to assure the loads are balanced. This is the same energy-balance problem that any car has with its differential. $\endgroup$ Feb 22, 2020 at 0:42
    $\begingroup$ I have to dig up a pic or a video of that, just cant wrap my head around it. In the mean time, you are clearly headed towards an acceptable answer here 👍🏻 $\endgroup$
    – Jpe61
    Feb 22, 2020 at 0:50
15
The NK-12 engine uses a differential epicyclic (planetary) gearbox. Unlike the typical planetary gearboxes where one of the gears is fixed, here all three parts are moving: the turbine drives the sun, the planet pinion drives the front propeller, and the ring drives the rear propeller.
The gear ratios are the same between the front and rear, but the torque is not. The difference you see has to do with this torque difference, as well as with different rotating masses and friction during start. The torque is what is actually important.
If you hold one part, then the other two will be in the expected sync. Say, if you jam one prop and start the turbine, it will simply spin the other prop twice as fast. (But if you jam the turbine, things will be less intuitive: the props should turn in the same direction if you move one by hand). Now if you allow the turbine to free spin, you'll have two degrees of freedom, and the eventual relative RPM in such system will depend on the torque on each prop.
In the explanation below, I use this work by S. Falaleyev et al (pdf in Russian). Here is the diagram of the gearbox:
NK-12MW gearbox diagram
If we assume the torque balance such that the RPMs are the same (except the sign), the gear ratio will be (I skip the derivation):
$$i = 1 + 2(\frac{z_2 \cdot z_4}{z_1 \cdot z_3})$$
($z$ are the teeth numbers according to the diagram). For the given numbers we get $11.33$ (or rather, it should be $1/11.33 = 0.088$ reduction). The nominal speed of the props was just 735 RPM!
At the same time, the torque ratio (front to rear) is
$$\frac{M_f}{M_r} = -(1 + \frac{z_1 \cdot z_3}{z_2 \cdot z_4}) \approx -1.19$$
Thus, the front prop gets almost 20% more torque than the rear prop. This is why it spins up faster on start-up. (It is also lighter than the rear one).
At the nominal speed, the governor automatically sets a finer blade pitch on the rear prop to equalise the speeds. (Why not just accept higher speed/thrust from the front prop? Apparently, because the prop is limited by the tips speed, and we don't want the front one go supersonic while the rear one is relaxed).
    $\begingroup$ Excellent answer! $\endgroup$
    – Koyovis
    Feb 24, 2020 at 7:20
  • $\begingroup$ This is great, before, with the help of google translate I was able to get some info about the gearbox but it was very general. Your linked document seems very informative, I'll have to dig in deeper! Very nice how they combined the reduction gear and the CRP divider into the same gearset. $\endgroup$
    – Jpe61
    Feb 24, 2020 at 7:33
    $\begingroup$ Thanks for the document link, it's quite an interesting read. @Jpe61 let me know if you need help deciphering some passage. $\endgroup$ Feb 24, 2020 at 9:46
    $\begingroup$ brilliant! they use a differential gear as a natural torque splitter! $\endgroup$ Feb 24, 2020 at 18:39
  • $\begingroup$ What had me fooled here was that I though there would be resemblance to cars and their differentials. Then there's the thing that the planetary gear on NK-12 is not your garden variety epicyclic... $\endgroup$
    – Jpe61
    Feb 24, 2020 at 19:26
I can't offer the technical backup, but years ago, I read that if the props are designed to run at slightly different rpms, it reduces the otherwise-hellacious sound produced by the contra props. Noise has been an issue with these since engineers started using them (late WWII I think). Of course, none of the NK-12 powered aircraft are known to be "Whisper jets"...
  • $\begingroup$ This seems perfectly plausible. $\endgroup$
    – Jpe61
    Aug 2, 2020 at 8:16
