14
The "area rule" states that the supersonic drag on an aircraft is related to the total area on part of the aircraft. What is the exact definition of the rule? Why does this happen?
    $\begingroup$ It's related to the shape of the curve of cross sectional area as plotted along the longitudinal axis of the aircraft. In other words, let the x-axis be the fuselage station from the nose of the aircraft to the tail of the aircraft and let the y-axis be the cross sectional area of successive planes along the longitudinal axis of the aircraft and at 90 degrees to that axis. If a part of that curve has a sudden change of slope relative to the curve before and after that part, the area rule has been violated, and you will have greater transonic drag rise than if the curve was smoother. $\endgroup$
    – Terry
    Jun 23, 2014 at 16:18
  • $\begingroup$ I'm not an aerodynamicist so I'm not competent to write up a full explanatory answer, but I can point you to the Wikipedia article which has a lot of good information. $\endgroup$
    – TypeIA
    Jun 23, 2014 at 18:08
    $\begingroup$ Also keep in mind that there are at least two different area rules: one for transonic flight and one for supersonic flight. For supersonic flight the algorithm is far more complicated—as instead of normal sections you must track the cross-sectional area of the aircraft across planes at the Mach angle $\mu=sin^{-1}(1/M)$. $\endgroup$
    – Bryson S.
    Jun 24, 2014 at 5:47
16
You might have heard of the elliptical lift distribution which minimizes induced drag for a given span and a given lift. Area ruling is similar, but here it is about the lengthwise distribution of cross-sectional areas of a plane, and it minimizes wave drag at Mach 1.
The first picture is from a Junkers patent of 1944: Junkers found out in 1943 that transsonic drag can be minimized by shifting the parts of an airplane around. In this case it was the EF-122, a research project which became the Ju-287. The easiest bodies to shift were the engine nacelles, that is why the end product has such odd engine locations. The drawing shows several shaded cross sections along lines which carry Roman numerals: Plot the sum of all areas along each line over the aircraft's length coordinate, and you get a distribution which must be optimized such that it has the maximum area for the smallest gradients.
Illustration from 1943 Junkers patent
The next picture shows how those plots look like. This is from a different source, so it shows generic wing-body combinations. On the left is an airplane with a fuselage shaped like a Sears-Haak body. A Sears-Haak body is an optimum shape for the biggest volume with a given wave drag and was discovered by Wolfgang Haak in 1941 and again by William Sears in 1947. The wings come on top and mess up the area distribution by creating a bump in the middle.
The right plot shows what can be achieved by taking all parts of the airplane into account. The difference is shown in the small center plot.
Comparison of areas and drag over Mach of regular and area-ruled aircraft
How this is done: Take away from the fuselage what is added by the wings. The result is a fuselage wich looks like a coke bottle. You can also add Küchenmann bodies; older airliners have plenty of them. Look especially at fuselages like those of the Blackburn Buccaneer, or T-tails like those of the Illjushin Il-62 or the Tupolev Tu-154. Today, things like engine pylons or flap track fairings are used as Küchemann bodies to smoothen out the lengthwise area distribution, and if you look carefully you will see the coke bottle technique on the fuselage around the horizontal tail of many airliners. They don't fly at Mach 1, but close enough that area ruling makes a difference already.
The dawing below shows the general concept and the magnitude of drag reduction achievable:
Gain in drag due to body waisting
    $\begingroup$ may I ask if you could add a more explicit picture of what a Küchenmann body is? $\endgroup$
    – Federico
    Jun 23, 2014 at 20:21
  • $\begingroup$ Wikimedia has a collection of pictures: commons.wikimedia.org/wiki/Category:Anti-shock_bodies $\endgroup$ Jun 23, 2014 at 20:27
  • $\begingroup$ ah, those! had no idea they were called that way. Thanks! $\endgroup$
    – Federico
    Jun 23, 2014 at 20:31
In essence, the area rule is a general rule of aircraft design which prohibits abrupt changes in a aircraft's cross-sectional area from one point to another on it's longitudinal axis, since these would create areas of low pressure in the surrounding airflow that would literally hold the aircraft back, reducing it's speed through form drag. The area rule is sometimes referred to as the "supersonic area rule" since it has more significance at transonic and supersonic speeds.
