Let's presume an airline flight piloted by 2 people: the Captain (assuming PIC role) and the F/O.
  • Is the F/O allowed to take manual control over the Captain actions?
  • Under what circumstances?
  • Could this create safety issues, for instance, the Captain trying to recover control from the F/O?
  • What does CRM suggest about this matter?
  • $\begingroup$ Please note that positive control transfer requires a 2-way conversation. It should go "(FO) My Plane, (CAP) Your Plane, (FO) My Plane". $\endgroup$
    – Ron Beyer
    Feb 14, 2020 at 13:03
    $\begingroup$ It's my understanding that Captain is a rank, and PIC is a role. Your question conflates the two terms. $\endgroup$
    – Jamiec
    Feb 14, 2020 at 15:07
    $\begingroup$ I thought the standard phraseology was "I have control", "you have control", "I have control". As long as the goal (make sure both F/O and capt know who's in control of the aircraft's trajectory) is reached, i supposed phraseology is not that important. $\endgroup$
    – Manu H
    Feb 14, 2020 at 15:30
  • $\begingroup$ Closely related: aviation.stackexchange.com/questions/23839/… $\endgroup$
    – Ralph J
    Feb 14, 2020 at 19:01
  • $\begingroup$ @ManuH Each operation can specify what phraseology is expected. Where I fly (USA), "I have the aircraft" is common, but if everyone is standardized to "I have control" that would work equally well. "I have it" would be a poor choice, as "it" is ambiguous & has in fact caused problems. Thus the need for an unmistakeable, and standardized direct object for the statement. But "control" or "aircraft" or "airplane" or etc are all good. $\endgroup$
    – Ralph J
    Feb 14, 2020 at 19:05
15
Pretty much every FO struggles with this. Technically yes, in the extreme case. If the actions of the capt are about to get everybody killed or otherwise endanger the aircraft, the FO is supposed to have the authority and an obligation, after a suitable verbal interchange, to intervene by saying "I have control" and take over. Generally there needs to be a trigger such as a situation where the capt does something that deviates outside normal operating limits, procedures, or protocols.
If the capt declines to hand over control, because, say, the capt has gone off the deep end, well you have a problem. But in most cases of suspected suicide by plane for example, the suicidee waits for the other crew member to use the rest room and locks the cockpit door - one unintended consequence of reinforced cockpit doors.
The more likely case is a capt that is disoriented or fixated, and in theory an FO who intervenes with proper procedure and with enough "authority" should be able to do it and a capt is expected to relinquish control in such a situation.
But however well trained the crew is, they are two humans and you can't predict what's going to happen. Different airline cultures apply this kind of thinking more strongly than others. At some airlines the FOs are encouraged to be maybe a little too forceful for most captains' tastes, questioning everything, and others, it's the old fashioned "shut-up-and-pull-gear" culture. This is still a serious problem outside of "western" operators, in countries that have strong patriarchal cultures, which is partly why you see so many "expat" American, Australian/NZ, Canadian, British, or European captains at far east airlines.
But even in up-to-date places like Canada, FO inassertiveness can be a problem. First Air 6560, pretty much the only major crash of a heavy in North America in almost 20 years (excluding runway excursions and Sully's adventure), is a classic case of an FO failing to intervene to thwart an incompetent captain who develops fixation tunnel vision and breaks the most basic rules of the book. Every FO needs to read the Transportation Safety Board report.
  • $\begingroup$ totally OT, but wow, looking at the pic of the 737-200 in that wiki article points out just how tiny the original engines were on those things and why Boeing's had to jump through so many hoops to put bigger ones on 'em. $\endgroup$
    – FreeMan
    Feb 14, 2020 at 15:12
  • $\begingroup$ A slightly tangential comment, but could anyone recommend any research (preferably accessible online) regarding this issue, i.e. socio-cultural aspects in CRM? I'd also be interested in similar research regarding gender variation (e.g. has research shown differences in CRM between all-male, all-female, and mixed-gendered crews). $\endgroup$
    – user12873
    Feb 14, 2020 at 17:56
    $\begingroup$ But in most cases of suspected suicide by plane for example, the suicidee waits for the other crew member to use the rest room and locks the cockpit door In most cases?? Has this happened more than once? Other than the famous Germanwings 9525, I can only find this incident that followed the same story. $\endgroup$
    – J...
    Feb 14, 2020 at 20:17
    $\begingroup$ There was also Silk Air en.wikipedia.org/wiki/SilkAir_Flight_185 so that's three, and I can't recall any cases of what you would call a physical fight over the controls in order to crash with both seated although maybe one or two have occured, so "most" is not too unreasonable I think, and it's the most likely way someone is going to do it going forward anyway. $\endgroup$
    Feb 14, 2020 at 20:40
    $\begingroup$ @John EgyptAir 990 had an FO wait for the captain to leave but didn’t have a lockout. $\endgroup$
    – cpast
    Feb 15, 2020 at 20:20
13
Yes, the FO is allowed to take over control from the captain on his own initiative, if the circumstances justify it.
One case that I know off where it saved the day was this incident of Lufthansa. On rotation for take-off the aircraft started to roll. Corrections by the captian only aggravated the situation until very quickly the aircraft's wingtip was almost hitting the ground. The FO assumed control (announcing 'I have control') and restored the aircraft's attitude. After troubleshooting they found out that the roll input on the sidestick of the captain was reversed. (The reason behind this is interesting as well, but off-topic in this question)
Basically if the FO deems that the actions of the Captain are an imminent safety risk to rhe aircraft, he/she must assume control of the aircraft.
    $\begingroup$ This is an interesting one which brings up a problem with FBW systems. What if the capt, in fixation mode, had hit the override? $\endgroup$
    Feb 14, 2020 at 18:19
