I'm a flight sim user practicing instrument navigation with a short and apparently simple flight, SBMG to SBLO (South America). The distance between the two airports is 49.5 nautical miles (the simulator tells me). My simulator is X-Plane 11. The aircraft is the Cessna 172.
I've flown the mentioned flight a couple of times, but I'm afraid I am making mistakes. There are a couple of questions I'd like to make.
Let's start with this SBMG SID chart (these charts come from AISWEB). The path with red dots is the one I'm following.
(1) You see 096 >
on the first 3 nautical miles? Does it mean I should track course 096
on the LON
VOR right after takeoff, or is it just the heading I should be on for the first 3 nautical miles? You see, I'm having trouble figuring out what is the reference navigation aid for these headings/radials.
(2) After passing MG123, I start to track the 100
radial on the LON
VOR for 47 nautical miles. After 47 miles I switch to the approach chart. Is that correct?
The next chart is a IAC for SBLO. It has a VOR/DME arc.
(3) I am still tracking 100
towards LON
, but the nearest entry point for the arc is 090
. After 47 nautical miles, I am too close to SBLO to change my course, and it's time to enter the arc already. I feel I missed something.
