The downwash is caused due to higher pressure below the wing than above it (for a positive lift generating wing that is). What I am not able to understand is how would the flow be in a gross sense? Will the flow move bottom to up around the wing tips and move top to bottom along leading and trailing edge? I thought of this because it is the only way I am able to justify that downwash induces a negative velocity component which decreases the angle of attack that the wing sees at the leading edge.
But can’t the air also move bottom to up along leading or trailing edge? To me, at leading edge it seems unlikely based on intuition because of the air upstream constantly trying to direct the air ahead but at trailing edge it seems more likely.
So what is the correct visualisation of downwash over a finite wing?
