27
For me, the term 'airliner' conjures up an image of a passenger jet that is capable of hosting a large number of passengers¹ but I'm finding it difficult to source a reputable definition or etymology despite the term has been sourced int the early 20th century.
Since the term has been in use since 1908, jet as in jet airliner may be inferred by the modern user but it obviously wasn't part of the original definition.
The word itself would seem to indicate that airliner refers to an aircraft used by an airline (a company that provides air travel for the public), but would that extend to bush pilots with small prop-driven Cessnas or passenger helicopters?
airliner - A large passenger aircraft. A large plane for carrying passengers: a commercial/commuter airliner
  source: Cambridge English Dictionary
airliner - An airplane operated by an airline
  source: Merriam-Webster Dictionary
  Is this an 'airliner'? How many passenger seats need to be added before it becomes one?
  (image courtesy of The Bush Pilot Company)
The term seems so vague that even the tag on this site only uses 'large' to define size or capacity.
Some reference work definitions include cargo aircraft but the predominant emphasis seems to be on passenger aircraft with no upper or lower limit criteria.
I suppose that this term could be relative to the observer or situation but if the term 'airliner' was used in FAA regulations then I'm sure there must be an appendix somewhere that provides a definition. My research has come up empty.
Apologies if this is a dumb question and the term is intentionally meant be vague with only 'large aircraft' or 'many passenger' as criteria. Given proper references as support, that could be an answer.
¹ This previous question got me wondering exactly what was the criteria before any aircraft could be called an 'airliner'.
  • $\begingroup$ There is no number that magically turns something from something like a "commuter aircraft" to an "airliner". They are just colloquial terms to refer to passenger aircraft, typically for paying passengers. $\endgroup$
    – Ron Beyer
    Feb 10, 2020 at 19:52
    $\begingroup$ "if the term 'airliner' was used in FAA regulations then I'm sure there must be an appendix somewhere that provides a definition" - Is that term used anywhere, though? $\endgroup$ Feb 10, 2020 at 19:54
  • 8
    $\begingroup$ Trust both Cambridge and Merriam Webster. I don't think you will find an FAA definition because they don't make this distinction. There are weight categories and passenger categories however. 10+ passengers and 12,500 lbs are magic numbers that change what regulations apply, but neither really changes the common use of the term "airliner" that you are asking about. $\endgroup$ Feb 10, 2020 at 20:11
    $\begingroup$ @Jeeped - your last sentence is 1000% correct. For example, the terms "luxury sedan", or, say, "crossover" are used regarding cars in the auto industry. There is no "specific, formal, definitive" definition whatsoever for those car terns. An air "liner" simply comes from "liner" (ie, in the passenger ship era). That's all there is to it. $\endgroup$
    – Fattie
    Feb 11, 2020 at 12:01
    $\begingroup$ As most of the (really good) answers below allude to, it's kind of like asking which of the buildings in NYC are skyscrapers and which are just normal buildings. You've come across another example of the "sorites paradox" (a.k.a. the "heap problem"): en.wikipedia.org/wiki/Sorites_paradox $\endgroup$
    – Jeff Y
    Feb 11, 2020 at 20:38
7 Answers 7
42
I think there's a misunderstanding here that airliner ("an airplane operated by an airline") is directly derived from airline. While it is a reasonable definition, "airliner" predates airline. (Mirriam Webster: airliner 1908, airline 1910).
An airliner is a portmanteau of air and liner, a liner being any passenger ship plying between ports along regular "lines" (as distinguished from transient ships using those ports). By the early 20th century a liner was generally understood to mean any large, passenger-carrying vessel operating a route between major ports (think Titanic etc.). You'll notice how airliners travel between airports - nautical words and phrases were adopted in the early days of flight.
So an airliner should be
  • passenger carrying
  • large
  • travels between airports, rather than having one fixed point of operation
It's a definition that still fits, and covers any commercial aircraft over a certain size. While there's not a specific point at which an aircraft becomes large enough to be called an airliner, I think it does impart some sense of largeness or capacity that an 'ordinary' plane does not possess.
(You might even say that a better definition of airline is "an air transportation system that operates airliners"!)
    $\begingroup$ The claim that "airliner" predates "airline" doesn't follow from the first-known-use dates provided by Merriam-Webster. $\endgroup$
    – Nat
    Feb 11, 2020 at 6:25
  • 10
    $\begingroup$ Don't forget that companies operating 'liners' quite often used 'line' in their name... as example 'White Start Line' operated the Titanic and the Olympic, so the addition of 'air' to 'line' and 'air' to 'liner' were both logical steps and may well have happened around the same time. $\endgroup$
    – houninym
    Feb 11, 2020 at 8:49
    $\begingroup$ The nautical theming is also because airliners were boats in the early days. It was the only practical way to have a large aircraft, since mile-long paved runways were not yet a thing. I'm not kidding. Airplanes could and did land in the Hudson River! Twice! $\endgroup$ Feb 12, 2020 at 5:46
    $\begingroup$ 1936 for "airline" (in this sense) and 1901 for "airliner", per Ngram. (Note that both get many "false hits", so it takes some Ngram-fu to sort it out.) $\endgroup$
    – Hot Licks
    Feb 13, 2020 at 0:51
    $\begingroup$ >airline (n.) also air-line, 1813, "beeline, straight line between two points on the earth's surface" (as through the air, rather than over terrain), from air (n.1) + line (n.). From 1853 and in later 19c. especially in reference to railways that ran directly between big cities in the U.S. instead of meandering from town to town in search of stock subscriptions as early railways typically did. Meaning "public aircraft transportation company" is from 1914. – etymonline.com/word/airline $\endgroup$
    – Mazura
    Feb 13, 2020 at 1:51
The term airliner generally does not refer to a particular aircraft, but rather a whole aircraft type. This makes the literal definition of the word by Merriam-Webster
somewhat invalid since this can only apply to a single aircraft.
The key difference between an airliner type and other types is that the aircraft manufacturer works together with airlines during the design process, meaning an airliner is designed to be operated by airlines. Airlines will define what they expect of a new airliner in terms of passenger capacity, range and fuel efficiency. The manufacturer can then design a new aircraft based on these design constraints. This ensures that the airlines get the aircraft they want and that the manufacturer can sell the new aircraft.
E.g., Boeing launched a new version of the 737 MAX after Ryanair requested an increase in passenger capacity, the 737 MAX 200:
Boeing developed the 737 MAX 200 in response to the needs of the fast growing low-cost sector, which is forecasted to account for 35 percent of single-aisle airline capacity by 2033. While the heart of the single-aisle market will remain at 160 seats, the 737 MAX 200 will provide carriers like Ryanair with up to 11 more seats of potential revenue and up to 5 percent lower operating costs than the 737 MAX 8, driving economic growth and increasing access to air travel.
(boeing.com)
This does not mean every Boeing 737 will be operated by an airline. Boeing even produces a dedicated version for the private market, the Boeing Business Jet (BBJ). But the type was designed with airlines in mind. This is what makes the difference compared to a non-airliner, which is designed with other customers in mind (private or commercial, but not airlines). Again, some aircraft of this non-airliner type might be used by an airline and hence be technically called an airliner according to Merriam-Webster, but the whole type is not an airliner.
  • $\begingroup$ That's a pretty good definition relative to an airliner's primary purpose. $\endgroup$
    – user46185
    Feb 10, 2020 at 21:32
    $\begingroup$ Funny - the MW definition is totally wrong. $\endgroup$
    – Fattie
    Feb 11, 2020 at 11:59
  • $\begingroup$ Your first paragraph is not true. You are getting wrapped around the axle over singular vs plural. $\endgroup$ Feb 12, 2020 at 15:30
  • $\begingroup$ @MichaelHall I disagree. People say "the Boeing 737 is an airliner", they don't say "this 737 is an airliner, but that one over there is not". $\endgroup$
    – Bianfable
    Feb 12, 2020 at 16:18
  • $\begingroup$ @Bianfable - I agree with the first statement. I also agree with the second statement if the other 737 is configured as a private business jet. However, if you are at a Southwest Airlines terminal you could say "This 737 is an airliner, and so is that one, and so is that one... " They are all airliners! (plural) $\endgroup$ Feb 12, 2020 at 17:00
The term “airliner” is absent from the FAR/AIM. Maybe a definition can be inferred to mean any aircraft not in the Normal Category. And/or one that is in the Commuter or Transport category.
23.2005 Certification of normal category airplanes. (a) Certification in the normal category applies to airplanes with a passenger-seating configuration of 19 or less and a maximum certificated takeoff weight of 19,000 pounds or less.
This is an inexact way of loosely defining airliner. It would kind of make sense since the pilots generally flying them are Airline Transport Pilots. The only reason I mentioned the ATP certificate is that there are few if any references that combine Airline with any quantitative way of measuring aircraft size. Technically, a type rated private pilot can fly a B747. Or, at least I see no restrictions against it in 61 nor 91.
Part 125 also addresses aircraft over 20 seats and 6000 pounds of cargo capacity. But, I wanted to be inclusive of everything above 19000 lbs and 19 seats. Regardless, neither part completely and adequately addresses the original question since the term airliner is never used. Only interpretations from the Merriam-Webster dictionary seem to offer any insight.
  • $\begingroup$ So far this does appear to infer some 'official' lower limit to an 'airliner'. Now I'm wondering how Qantas or Alaska Airlines would feel about their fleet being categorized as 'Not Normal'. 😊 $\endgroup$
    – user46185
    Feb 10, 2020 at 20:17
  • $\begingroup$ @DeanF, doesn't 10+ pax bump a carrier from part 135 to part 121, and require an ATP? $\endgroup$ Feb 10, 2020 at 20:26
    $\begingroup$ @MichaelHall - No, a 10 pax seat limit is not imposed on Part 135. Extra regs for 135 are required to be met if there are more than 9 seats (135.141 - 135.180). Some of the requirements are not applicable till 19 or 20 seats. $\endgroup$
    – Dean F.
    Feb 10, 2020 at 21:24
    $\begingroup$ The only reason I mentioned the ATP certificate is that there are few if any references that combine Airline with any quantitative way of measuring aircraft size. Technically, a type rated private pilot can fly a B747. Or, at least I see no restrictions against it in 61 nor 91. $\endgroup$
    – Dean F.
    Feb 10, 2020 at 21:30
  • $\begingroup$ You point to Part 23. You should point to PART 25—AIRWORTHINESS STANDARDS: TRANSPORT CATEGORY AIRPLANES which is the standard for aircraft used in air transport (i.e. by airlines authorized under PART 125—CERTIFICATION AND OPERATIONS: AIRPLANES HAVING A SEATING CAPACITY OF 20 OR MORE PASSENGERS OR A MAXIMUM PAYLOAD CAPACITY OF 6,000 POUNDS OR MORE... $\endgroup$
    – Gerry
    Feb 11, 2020 at 12:29
In reality, the word is used in (at least) two different manners, which inevitably leads to some confusion.
On the one hand, an airliner is ANY aircraft, however small, that is operated by an airline company, in contrast to those owned/operated by a private pilot.
The second, probably commoner definition is size-based, though somewhat loosely. In the 1930's, a luxury airliner may have had less than a dozen seats, while these days nothing short of about a hundred seats would normally be regarded as an airliner.
  • $\begingroup$ I class commuter aircraft as airliners myself, but maybe that's just me :) $\endgroup$
    – jwenting
    Feb 13, 2020 at 4:45
The word pretty much means what it's more or less consistently used for - there certainly isn't any formal definition to get hold of.
The characteristics of an airline though would be to own a fleet of vessels, that ply particular routes, that generally travel distances further than a typical privately-owned craft might be expected to cover, according to some sort of schedule, as a service.
An airliner would be the kind of craft that could be expected to live its working life in that kind of service.
And that's about as good as you'll get.
  • $\begingroup$ I don't think travel distance is a factor. Airliners often make short hops. I don't think length of service is either. A 737 is an airliner so long as it's in the service of an airline and ceases to be an airliner as soon as it's not whether that time was 3 years or 30. $\endgroup$
    – dev_willis
    Feb 13, 2020 at 14:25
  • $\begingroup$ Sure, though the 737 is generally considered an airliner, not matter whether any individual 737 is still being used as one. Probably some airlines do have routes that are exclusive short hops, but that's why I said "generally" not "universally". $\endgroup$ Feb 14, 2020 at 20:39
  • $\begingroup$ That makes sense. My thought was just that, if we're looking for a definition of airliners, we need one that covers them universally. So I was trying to help refine the definition. $\endgroup$
    – dev_willis
    Feb 16, 2020 at 5:17
  • $\begingroup$ That's my point, that there isn't any definition, just a general usage that more or less seems to cover a certain constellation of characteristics. $\endgroup$ Feb 16, 2020 at 8:37
An airliner is any commercial aircraft that regularly flies the same route, or "line," regardless of the size or capacity of the aircraft. Airliners are operated by airlines and while the big jets are what typically come to mind, airlines also operate smaller prop planes on shorter lines and these are still airliners.
It's the service the aircraft performs and not the type of aircraft that makes the difference. E.g., a 747 owned by the Sultan of Brunei is not an airliner. But if an airline bought it from him it would then become an airliner. If the airline later sold it back to him it would then cease to be an airliner. Another example are the 747s (technically VC-25s) that are typically used as Air Force One.
    $\begingroup$ I would be interested to know the reason for the downvote. $\endgroup$
    – dev_willis
    Feb 13, 2020 at 14:40
  • $\begingroup$ FedEx is an airline (technically called FedEx Express)! $\endgroup$
    – Bianfable
    Feb 13, 2020 at 15:02
  • $\begingroup$ @Bianfable I see what you mean. I'll update my answer. $\endgroup$
    – dev_willis
    Feb 13, 2020 at 15:12
  • $\begingroup$ @Bianfable I've corrected my mistake. Thank you for pointing it out! Care to remove your downvote now? :) $\endgroup$
    – dev_willis
    Feb 13, 2020 at 15:29
-2
For many vague terms without specific, precise legal or regulatory definition, the answer will rarely be binary, True or False. It helps to think in terms of probability. If you ask the question: "Is this an airliner?" to 100 random people, how many would answer yes?
    $\begingroup$ That's a pretty good concept but unfortunately, my brain is pretty binary and I got arrested the last time I demanded opinions from 100 bystanders. I'm very serious. You can even look it up. The case is known as Jeeped vs Several. $\endgroup$
    – user46185
    Feb 12, 2020 at 23:47
  • $\begingroup$ @Jeeped Your brain being pretty binary does not alter the nature of reality. You may, of course, percieve reality as you like, but since you have already gotten into trouble with that, it might be worth your while to learn some flexibility. $\endgroup$
    – Jpe61
    Feb 13, 2020 at 10:58
  • $\begingroup$ I would be interested to know why my answer was downvoted. Without comment, it’s hard to improve anything $\endgroup$
    – Didier
    Feb 14, 2020 at 0:57
