The vast majority of MEMS-based IMUs are formed by an accelerometer and a gyroscope, providing linear acceleration and angular rate measurements respectively.
However, having available the angular acceleration would be useful for a more precise kinematic model when integrating to find the pose. Judging by this IEEE review, there are sensors for angular acceleration, therefore it doesn't seem to exist a fundamental limitation in the ability to have direct measurements of it.
Why is it that the standard has become to have angular rate as the source of information for rotational motion and not angular acceleration?
    $\begingroup$ It is probably used internally to calculate the angular rate, what makes you think it's not? It may not be useful to other systems, but an IMU is an integrated piece of equipment that a manufacturer supplies. The raw data probably isn't useful outside the IMU. $\endgroup$
    – Ron Beyer
    Feb 10, 2020 at 12:58
My answer assumes that you're asking about having IMUs measure angular acceleration instead of angular rate; if meant they should measure angular acceleration in addition to angular rate, then I apologize for misunderstanding you.
I'm not sure where you're getting that information. When integrating to find the attitude, the angular rate is much more useful than the angular acceleration.
An attitude indicator essentially just takes the angular rate and integrates it. However, there are two sources of error here: errors from the sensor, and the fact that the direction of gravity changes as the earth rotates and as you move across the surface. But both of these errors can be corrected by mixing proper acceleration into the calculation.
On the other hand, if you only had access to angular acceleration data, you'd need to integrate twice to find the attitude: once to come up with an estimate of the angular rate and again to come up with an estimate of the attitude. (Why would you want to have to integrate to come up with an estimate of the angular rate, instead of just measuring the angular rate?)
This would introduce a third source of error into the attitude indicator: errors that result from accumulated errors in the angular rate estimate. I think these errors would be much more difficult to correct.
I think that the biggest problem is that in a coordinated turn, the angular acceleration is 0 and the lateral proper acceleration is also 0, so without measuring angular rate, an IMU would be unable to distinguish a coordinated turn from straight-and-level flight! That's a critical flaw.
In short, you need a reliable measurement of angular rate, and that can't be obtained from a measurement of angular acceleration.
  • $\begingroup$ You bring a good point with the coordinated turn, plus the errors derived from double integration (yes, there I had in my mind having both angular rate and angular acceleration, but is not what I stated). However similarly you could say that for an object moving with constant linear velocity: accelerometer can't measure it. I guess what calls my attention is the asymmetry on having in the IMUs velocity for rotational movement and acceleration for linear movement $\endgroup$
    – A. Fenzry
    Feb 10, 2020 at 20:27
    $\begingroup$ Well, the asymmetry is because it's possible (and useful) for an IMU to measure absolute rotational velocity, whereas it's not possible (even though it would be useful) for an IMU to measure absolute linear velocity. $\endgroup$ Feb 10, 2020 at 20:29
