Do modern aircraft still have PCMCIA for engine monitoring?
    $\begingroup$ I wouldn't be surprised if floppy disk is still in use. $\endgroup$ Feb 2, 2020 at 11:47
  • $\begingroup$ I didn't know they used PCMCIA. I thought they used more specialised hardware. $\endgroup$
    – Manu H
    Feb 2, 2020 at 12:39
  • $\begingroup$ @ManuH According to this reddit post Airbus, Boeing, and Embraer use (or used) them: "It’s a memory card that goes into the FDIMU (Flight Data Interface and Management Unit) and records various flight parameters, engine performance data, interfaces with the ACMS (Aircraft Condition Monitoring System), ACARS and various other computers on the plane." $\endgroup$
    – PerlDuck
    Feb 2, 2020 at 13:07
  • $\begingroup$ My plane uses a micro SD card to download engine performance data. Other boxes in my plane use a USB stick. The plane is not modern (46 years old) but the avionics are modern and engine monitoring system are new. $\endgroup$
    – CrossRoads
    Feb 3, 2020 at 19:21
  • $\begingroup$ Without a clear definition of "modern aircraft", this question is too broad. Many airplanes, even older aircraft that have been retrofitted with newer electronics, won't use PCMCIA, because newer, improved I/O interfaces are available. On the other hand, surely there are some aircraft flying today that are essentially "modern" as compared to the early days of aviation, and which still have PCMCIA interfaces. Please be more specific as to what you consider "modern". (That said, I do doubt that a clean sheet 21st century design would be using PCMCIA.) $\endgroup$ Feb 4, 2020 at 6:05
