Is it possible to certify an aircraft under FAR 23 Commuter Category with single pilot ops only? Like, there is just one seat in the cockpit and up to 19 passengers. Does anyone know of such an aircraft flying?
  • $\begingroup$ Your title and your question don't match, but I'm sure the answer to both is "no". $\endgroup$
    – Ron Beyer
    Jan 26, 2020 at 22:33
  • $\begingroup$ The Metro 23 is called the "23" because it's a part 23, amendment 34 plane. $\endgroup$
    – acpilot
    Jan 27, 2020 at 20:22
4 Answers 4
It looks like it's possible but not common. There's an STC for the Twin Otter that authorizes single-pilot operations in the commuter category if various upgrades have been made. At least, that's my reading of it:
The Twin Otter DHC-6-300HG™ type rating designation is DHC-6HG and may be operated with or without a second in command (SIC) with certain limitations. The Airplane Flight Manual Supplement (AFMS) lists equipment that must be installed and operative to operate the aircraft single pilot.
And:
FAA STC SA02682LA incorporates upgraded engines, upgraded propellers, increased maximum takeoff weights (MTOW), structural and aerodynamic modifications, and the aircraft category and design characteristics were updated to Title 14 of the Code of Federal Regulations (14 CFR) part 23 commuter category.
HondaJet is certified for single-pilot operation for Part 23. Note that 14 CFR Part 23 Amendment 64 and later removed Utility, Acrobatic, and Commuter Categories and now refer to all of them as Normal Category.
The Phenom 300 is certified under Part 23 and you can be typed as single pilot in it.
  • $\begingroup$ Wikipedia lists max. 6 passengers... $\endgroup$
    – Koyovis
    Feb 2, 2020 at 8:57
  • $\begingroup$ The 300 is certified for up to 10, Wikipedia is wrong again. $\endgroup$
    – Mike Brass
    Feb 3, 2020 at 0:13
Florida Flight Center says
CE-501SP and the CE-551SP are FAR part 23 certified aircraft. Both of these airplanes may be flown single pilot without a waiver as long as your checkride was completed in one of these aircraft to single pilot standards.
