What do these symbols mean in an airport?
  • $\begingroup$ Welcome to the site. Can you please provide context, like where did you see it? A clearer title will help others looking for the same answer. $\endgroup$
    – user14897
    Jan 25, 2020 at 23:58
The answer is stated in ICAO Annex 12 (Search and Rescue)PDF. (See Appendix I relevant to Chapter 5, 5.8 of the Annex.)
Ground-air visual signal code for use by survivors:
G/A used by survivors
Ground-air visual signal code for use by rescue units:
G/A used by rescue units
Note 1.— Symbols may be formed by any means such as: strips of fabric, parachute material, pieces of wood, stones or such like material; marking the surface by tramping, or staining with oil.
  • $\begingroup$ Thank you for the answer. $\endgroup$
    – montblank
    Jan 26, 2020 at 4:34
  • $\begingroup$ Very interesting. In "Use of Weapons", Iain M Banks adapts this kind of signalling. Zakalwe marks his location for airborne pickup on a battlefield by making a Z - by arranging bodies... $\endgroup$
    – SebTHU
    Oct 1, 2021 at 12:28
