11
Source: tkaviation.net
I suspect it's related to the fuel system, but it's only found on the left wing (see the yellow circle, not the pitot-tube). I haven't been able to find the right keywords to find anything about it.
I'm hoping to know its function and how it does it.
  • $\begingroup$ The pitot tube is to the left of the strut. It is a fuel vent. You will often find fuel leaking out of it when the plane is parked on a slope. $\endgroup$
    – JScarry
    Jan 20, 2020 at 4:37
  • $\begingroup$ @JScarry two of them? I've annotated the photo, though there was already a circle. $\endgroup$
    – user14897
    Jan 20, 2020 at 4:44
    $\begingroup$ Cessnas with a fuel selector that has a both position usually have one fuel vent. The Cessna 210 does not have a both position and the fuel vents are in the wing tip fairing on each side. $\endgroup$
    – JScarry
10
It's the fuel tank vent. It prevents forming a vacuum in the gas tank as it's drained, which would prevent further fuel flow to the engine.
    $\begingroup$ Thanks. How come it's on the left side only? $\endgroup$
    – user14897
    Jan 20, 2020 at 4:48
    $\begingroup$ The tanks are plumbed together so only one vent is necessary. $\endgroup$ Jan 20, 2020 at 4:57
    $\begingroup$ @ymb there is a line that connects the two tanks. That’s one reason why it’s difficult to use fuel from only one tank in a Cessna. It’s also why, when you are refueling on a slope, you always want to fill the tank on the lower side first because otherwise the fuel on the higher tank drains to the lower tank and you have to go back and refill it. $\endgroup$
    – JScarry
    Jan 20, 2020 at 4:58
  • $\begingroup$ @JScarry: If you fill the lower tank first and then fill the higher tank, won't the fuel from the higher tank still drain to the lower tank and overflow out the tank vents? $\endgroup$
    – Vikki
    Mar 20, 2021 at 0:10
    $\begingroup$ @Vikki-formerlySean I don’t know. It’s been a while since I’ve flown Cessnas and I just don’t remember. $\endgroup$
    – JScarry
    Mar 20, 2021 at 1:11
I found a diagram from a 1978 Cessna 152 that explains the fuel system. Note the interconnected tanks. This one only has one vented cap, but because of leaking and water being trapped in rubber fuel bladders, most Cessnas have had their fuel caps replaced with Monarch caps, which are both vented.
Cessna 152 Fuel System
The checklist requires that you check the fuel vent for obstructions.
Cessna 152 Checklist
    $\begingroup$ Excellent thanks / Possible dumb question: If both caps are now vented, does that mean that the underwing vent tube has become vestigial? Or is it still needed for higher than ambient pressure (hence the pitot-like design)? $\endgroup$
    – user14897
    Jan 20, 2020 at 20:08
    $\begingroup$ @ymb1 I don’t know the answer to that but I think that the vent caps are there in case the main vent is clogged. That way fuel can still flow to the engine. Another example; my Cherokee has two under-wing vents and both caps are vented. The caps have a rubber fitting that will only open if there is lower than normal pressure in the tank. $\endgroup$
    – JScarry
    Jan 20, 2020 at 20:23
