Zenith's bush airplane
I would like to know the name (if any) and the specifications of Zenith's bush airplane? I would like to know the size, the diameter, the maximum load, bearing number/type, and so on. Seems that the front gear and the main are different in spec.
  • $\begingroup$ It's a Zenith STOL CH 701. See also here and the links on that page. Also here for the gear. $\endgroup$ – PerlDuck Jan 19 at 11:14
  • $\begingroup$ The two links are good. But unfortunately I can not see there the gear specs. $\endgroup$ – AirCraft Lover Jan 22 at 6:46
