In rural Australia there are farms that have private airstrips. My question is when an aircraft wishes to land at such a strip (for example a flying doctor) who handles the landing aspects of ATC. Things such as reporting on wind speed and direction, air pressure, ensuring that the strip is clear, advising on glide slope?
    $\begingroup$ Welcome to aviation.SE! This question might help, it isn't specific to Australia but it's fairly general. If you're new to the site, the tour might also be helpful. $\endgroup$
    – Pondlife
    Commented Jan 16, 2020 at 4:01
I can’t speak for Australia, but in the United States there are thousands of uncontrolled airports throughout the country, both privately and publicly operated. Larger, better equipped public uncontrolled airports have good facilities such as paved runways and taxiways, instrument approaches, automated weather reporting stations, pilot controlled airport lighting, FBOs, fuel and maintenance depots, etc. but many uncontrolled airports are simply grass, gravel or dirt strips with little or no facilities, particularly in back country or mountainous areas.
Typically the decision to go into these kinds of airports is at the pilot’s discretion and the pilot alone must make the final call as to whether they can safely take off and land at these locations. Bush pilots departing from said locations will typically carry small handheld weather stations used by mountaineers for determining local atmospheric conditions, winds, etc. Remote airports will use a standard left hand traffic pattern flown at 1000’ AGL, but many do not due to nearby terrain and are one way in/out. If a CTAF is not published for the airport, pilots will use the MULTICOM frequency of 122.9 MHz to announce their position and intentions.
Condition of the airport and runway are often not monitored and it is up to the pilot to determine if they can be used. Arriving traffic will often make a low, slow pass over the airfield to determine runway condition and look for obstacles which could impede landing.
All types of aircraft can and do use such airports but most often the aircraft operating from them are specially build bush aircraft with good STOL flight characteristics plus beefy landing gear and tires for operating from unpaved strips or off field operations.
    $\begingroup$ I can speak for Australia and can say that these procedures are almost exactly the same here, except FBOs are virtually unheard of. You've got to do everything yourself. $\endgroup$
    – Ben
    Commented Jan 16, 2020 at 11:43
There is very little air traffic control for such airstrips* precisely because there is very little traffic. Even a popular semi-backcountry strip, say Smiley Creek in Idaho, might see a dozen or two planes on a summer weekend. You just use your eyes, and monitor the CTAF and announce your intentions. Other places I might land and camp for several days without seeing another plane.
As far as weather &c goes, it's pretty much seat of the pants. You look at the wind sock if there is one, or other indicators such as sideways drift when you try to fly a straight course - say when you're making a low pass over the runway to check on condition, and scare deer, cows, antelope, or whatever. (Probably kangaroos in Australia :-)) Then you make a judgement call as to whether you can handle it or not.
As for glide slope, if you're flying a light plane in VFR conditions, you eyeball it. Larger but still uncontrolled may have luxuries like VASI/PAPI, or even pilot-controlled runway lights for night landings, but smaller strips don't.
*At least in the US: I'm not familiar with Australia, but don't see any reason why it should be different.
  • $\begingroup$ As far as weather &c goes typo? $\endgroup$
    – kevin
    Commented Jan 16, 2020 at 7:19
  • $\begingroup$ @kevin nope, just an older way of writing "etc." $\endgroup$
    – FreeMan
    Commented Jan 16, 2020 at 14:25
  • $\begingroup$ @FreeMan: Not so much older, but one that frustrates simple-minded typesetting algorithms that can't tell the difference between the period of an abbreviation, and the one at the end of the sentence. $\endgroup$
    – jamesqf
    Commented Jan 16, 2020 at 19:05
  • $\begingroup$ Pardon me, "more obscure". :) Your point is excellent, however, about avoiding the autocorrect autocapitalizing the word after an abbreviation - I hadn't thought of that one. I don't often text "etc", but I will use "&c" from now on (when I remember) to avoid that minor annoyance. (Or, I'll just skip the period as I did there without realizing it.) $\endgroup$
    – FreeMan
    Commented Jan 16, 2020 at 19:10
