With tens of thousands of flights daily, many out of smaller and perhaps 'sketchy' airports, it would seem that serious incidents caused by contaminated fuel should happen a lot more often (in a quick Google I only found two). Do commercial jets have some system whereby the airplane itself can verify fuel quality as it is loaded? Or do pilots & airlines rely entirely on the fuel supplier?
    $\begingroup$ +1 for researching. Can you please share the two examples? $\endgroup$
    – user14897
    Jan 10, 2020 at 13:38
  • $\begingroup$ One over Colorado at altitude, restarted and did emergency landing in DEN. A second over Russia, flamed out on final and glided to a safe landing. I don't recall dates or carriers. $\endgroup$
    – GregT
    Jan 10, 2020 at 17:41
  • $\begingroup$ I found others, and I'd rule out (as a primary concern) the airport's sketchiness: DL-96 from Pittsburgh, PA and AZ-631 from Miami, FL. $\endgroup$
    – user14897
    Jan 10, 2020 at 19:03
  • $\begingroup$ The most famous such incident is probably Cathay Pacific flight 780 in which fuel contamination jammed the fuel metering valves and prevented adjusting engine power. $\endgroup$
    Jan 11, 2020 at 19:32
  • $\begingroup$ @ymb thanks for the links, the first one sounds like a fuel filter problem and the second one is not conclusive, not clear either were actually bad fuel vs fuel system giving false indications. $\endgroup$
    – GregT
    Jan 13, 2020 at 18:25
As you can see, the supply chain is big (with filters and water separators at various points). The short answer is that standards and quality checks are followed.
As for the jetliners, as far as I know they can't detect the fuel quality, but some can alert if issues arise in the fuel filters. The certification standards focus on engine restart capability and that it...
... should be demonstrated for the momentary shutdown from a high power or thrust setting, associated with the takeoff and climb flight regimes, and the extended shutdown at medium to high altitude where the engines may be "windmilling" and/or "cold soaked."
Fuel contamination is of the reasons mentioned in the engine restart section.
ICAO's Manual on Civil Aviation Jet Fuel Supply (on SKYbrary; PDF) is comprehensive as to the practices involved (the image above is from the manual).
1.2.1 Any business entity involved in the aviation fuel supply chain has an obligation to implement and comply with industry and/or company proprietary PSPs, as described in this manual, that cover the activities in which they are involved.
Supply and distribution, aircraft operators, and airport operators, each follow their respective policies, standards and procedures (PSP).
3.10.1 Any organization that manufactures, supplies or handles aviation fuel should have a documented training programme for its personnel. The programme should cover product quality, safe operation of equipment, emergency procedures and occupational health, as well as management systems for operational safety, environment and security. In particular, the programme should include in its scope a systematic way to identify hazards and effectively control risks to fuel quality, personnel, and facility and equipment or aircraft safety.
At each step the manual lists the various industry standards and manuals to follow.
