The Phoenix Mesa-Gateway Airport (KIWA) has a named obstacle departure procedure - the Phoenix Departure.
What's the correct phraseology for when clearance assigns it to you? Is it "N123AB, cleared to XXX, via the Phoenix Obstacle Departure"?
Sign up to join this communityThe Phoenix Mesa-Gateway Airport (KIWA) has a named obstacle departure procedure - the Phoenix Departure.
Items in parentheses on these charts are not said when referring to them by name. It's the same for other departures/arrivals that are RNAV, and for approaches that may be GPS or RNP.
It's called the "Phoenix One Departure", exactly as depicted in the title. Why do you think it would be something else?
This is an Obstacle Departure so this is not assigned by ATC. Some obstacle departures are textual based and some have an image depiction of the departure, such as this one. Part 91 pilots are not required to follow Obstacle Departures under an IFR flight plane but it is highly encouraged. Commercial flights must follow Obstacle Departure procedures and it is up to the pilot in command to seek them out and fly them not for ATC to assign them.
More information on IFR departure procedures can be found here.
