Waved like VHF , UHF and other themes like radio or something ....
  • $\begingroup$ Can you be more clear about your question? $\endgroup$
    – Jeff A
    Jan 4, 2020 at 20:44
    $\begingroup$ I'm voting to close this question as off-topic because it is not about aviation but rather about biology and physics. $\endgroup$ Jan 4, 2020 at 21:05
    $\begingroup$ In favour of the question: airports are places of extraordinarily heavy em load with navaids, radios, radars and huge amounts of people using their personal comms... $\endgroup$
    – Jpe61
    Jan 4, 2020 at 22:00
  • $\begingroup$ Related: aviation.stackexchange.com/q/65274/23223 $\endgroup$ Jan 4, 2020 at 22:58
  • $\begingroup$ I feel like it's not on topic. The question here is "Are radio waves harmful to health, at the levels found at airports?" We may have some idea of the level of radio waves found at airports, but the other part of the question is totally off topic. $\endgroup$ Jan 5, 2020 at 0:06
No. To people at the airport, the electromagnetic radiation from various sources relating to aviation (or anything else) is not dangerous.
Any electromagnetic radiation is, with enough intensity, possibly dangerous, even instantly lethal, but you can rest assured, that such intensities are not present anywhere a normal person has access to.
  • $\begingroup$ I disagree, weather radars are dangerous to ground crew and require specific procedures to mitigate said danger. $\endgroup$ Jan 4, 2020 at 23:00
    $\begingroup$ @AEheresupportsMonica hence "...anywhere a normal person has access to." I'm perfectly aware that some radars can fry your nuts if you manage to sneak close to one (I'm familiar with one case), but that's why access near them is limited. $\endgroup$
    – Jpe61
    Jan 4, 2020 at 23:09
  • $\begingroup$ thank you so much 🌹🌹🌹 $\endgroup$ Jan 5, 2020 at 6:42
