What is the proper term used when the plane is stopped and the engine is ramped up and after a certain thrust is reached, it suddenly starts off with a jerk.
The term I'm coming across the most is "static take-off" (even used by Airbus).
Its advantage is that it's using the least distance since you don't "waste" the distance it takes the engines to spool-up (in a jet anyway) to take-off power.
Not to be confused with "non-rolling take-off", which just means the aircraft was holding on the runway before the take-off run started. A non-rolling take-off is not a "static take-off" if the pilot didn't step on the brakes until the engines spooled up.
