New FAA Notam site marks certain notams as Snowtam and provides Runway Condition. I can decode E) part using FAA Runway Condition. But how can I decode the Q section. Is there a comprehensive source for decoding Notams?
FAA publishes same notam in 2 different formats. I am interested in decoding ICAO Format.
ICAO FORMAT:
12/057 NOTAMN  Q) ZBW/QMRXX/IV/NBO/A/000/999/4221N07100W005
  A) KBOS  B) 1912310152  C) 2001010152
  E) 09 FICON 5/5/5 100 PCT WET  OBS AT 1912310152.
DOMESTIC FORMAT:
!BOS 12/057 BOS RWY 09 FICON 5/5/5 100 PCT WET OBS AT 1912310152. 1912310152-2001010152
  • $\begingroup$ ICAO Annex 15 $\endgroup$
    – Ron Beyer
    Dec 31, 2019 at 5:53
    $\begingroup$ This is FAA's runway condition format, which is different than the one used in Europe i assume. So ICAO Annex 15 does not seem to fit into this. $\endgroup$
    – chickens
    Dec 31, 2019 at 13:32
So, a SNOWTAM actually has a different format, and your example is just a standard NOTAM in ICAO format.
This decodes into the following:
Series and number:        12/057
Nature of the NOTAM:      New (N in the NOTAMN)
Q) Qualifier line:
   FIR:                   Boston FIR (ZBW)
   NOTAM Code:            Starts with Q and the following four letters:
                          Subject: Runway (MR)
                          Condition: Not Specified / Plain Language (XX)
   Traffic:               NOTAM issued for IFR (I) flights and VFR flights (V)
   Purpose:               NOTAM selected for immediate attention of flight crew members (N),
                          for PIB entry (B), and concerning flight operations (O)
   Scope:                 Aerodrome (A)
   Limits:                FL 000 to FL 999 (000/999)
   Geographical location: 42°21' N 071° 100' W (4221N07100W)
                          Operation radius of the NOTAM: 5 NM (005)
A) Aerodrome:             Boston Logan (KBOS)
B) From:                  01:52 UTC 31 December 2019 (191231 0152)
C) Until:                 01:52 UTC 01 January 2020 (200101 0152)
E) Text of the NOTAM:     Runway 09 Field Condition
                          Braking action 5/5/5 (good for each third of the runway),
                          Runway is 100% wet
                          Observed at 0152 UTC on 31 December 2019
We could dig into the ICAO documents to find the official guidance, but different countries implement it differently sometimes anyway. Here's a good document that I found which breaks down the different codes.
