-5
I have looked at hundreds of photos on line but nothing that has the upswept wings and the downswept rear wings with just one tail. I'd like to see a picture so I can paint it properly - thanks
    $\begingroup$ Pleasse update your question with a picture by using the edit link $\endgroup$
    – Jamiec
    Dec 30 '19 at 21:14
  • $\begingroup$ Help us help you... Is this an aircraft you read a description of, or have you seen one in person? Do you have a photo? Have you Googled "F-4" to see if that is the one you are thinking or? If you don't provide us some feedback I am going to vote to close as too broad. $\endgroup$ Dec 30 '19 at 22:06
A fighter with "upswept wings and the downswept rear wings with just one tail"? sounds like an F-4.
BTW, "upswept" is called a "dihedral", and "downswept" is an "anhedral".
    $\begingroup$ F-4 is pretty much the only plane fitting the description, allthough only the outer part of F-4's wings were "upswept". $\endgroup$
    – Jpe61
    Dec 30 '19 at 21:12
