I've discovered an interesting WWI era model of an aircraft and I am trying to find out what could it be. It is 29" long and it looks like not a hobby model, but an inventor's prototype. I love the idea of the extra fuel tank above the cockpit. It connects with a bigger fuel tank near the engine. Any ideas?
4$\begingroup$ Welcome to the site. Personally, I am not sure that above the cockpit there is a fuel tank, looks like an attachment for the top wing $\endgroup$– FedericoDec 18, 2019 at 8:51
$\begingroup$ The unusual shape is similar to a Curtiss Carrier Pigeon. $\endgroup$– Party ArkDec 18, 2019 at 14:13
$\begingroup$ Hi Federico! There is a fuel tank at the very top. A small pipe is going down connecting it with a bigger size tank near the engine. I will try to upload more photos. $\endgroup$– RomakDec 18, 2019 at 15:46
$\begingroup$ OK, uploaded! It is definitely an extra fuel tank. $\endgroup$– RomakDec 18, 2019 at 16:03
$\begingroup$ Yes, the shape is similar to Pigeon! I believe it just does not look like just a mail carrier. I can see the round-shaped aim near the cockpit, which means the plane was likely designed for a battle. $\endgroup$– RomakDec 18, 2019 at 16:08
Beautiful find..., an original scale model from the 20s. At first glance, the rudder is a typical "Sturtevant" design..., but the rest of the fuselage appears to be from another aircraft, or a type of Sturtevant that I am not familiar with. It could also be a free work, a personal design by the modeler... It looks like an old rudder concept for a "modern" fuselage design.
Sturtevant S-4
Sturtevant S-2
Some details suggest that the builder wasn't trying to faithfully model a particular airplane, working from detailed diagrams and photographs as one does nowadays a hundred years later, but was instead incorporating elements from various airplanes from personal memory.
peculiar arrangement of ribs in the fin/rudder
conical top and bottom panels of cowling, easily soldered from flat metal sheet but rare on manufactured airplanes
too-deep fuselage: the position of the exhaust stacks and prop shaft makes one wonder what would have to be down in the belly.
A few more detailed photos (does the right side also have exhaust stacks?) would help to resolve this.
