Airfoil's cross section and wind direction Coanda's effect demonstration
Picture 2: source.
Consider I have an airplane and it wing, of course. The cross-section of the airfoil is as the picture 1. The leading edge and the wind direction are depicted there. The leading edge I depicted as simple as possible to make it easy to be understood. It is exactly a half of a circle. For clearer, you may see the second picture or watch the video of the link I provided above.
Then my question is, how do I calculate the air pressure in the leading edge's top bulge as in the first picture?
  • $\begingroup$ What is the final result you would like to get? Lift and drag? Or you need the actual pressure estimate? $\endgroup$ – JZYL Dec 6 '19 at 16:45
    $\begingroup$ Hey that's exactly what MY head looks like when I blow dry it! $\endgroup$ – John K Dec 6 '19 at 18:40
  • $\begingroup$ Quite strange no answer this question. $\endgroup$ – AirCraft Lover Dec 20 '19 at 0:25
