Push-pull configuration aircrafts usually feature identical engines and propellers working only in tandem for multiple reasons like higher speed, better climb rate, reliability, cost, ease of maintenance, etc.
It may sound unpractical for piston engines were saving fuel will not outweigh the downside of one engine being a dead weight but may be a good idea for lighter electric or a combo, where engines may also be optimized for different propellers.
Can it be possibly beneficial to have tractor prop for take-off:
  • blown lift
  • no FOD risk
  • less noise outside
and pusher specifically optimized for cruising:
  • larger diameter as no ground clearance issue
  • no parasite drag
  • more stability
  • less noise in cabin
Benefits to consider:
  • efficiency
  • higher achievable speed
  • higher altitude
  • still two motors for redundancy
Problems:
Stowing nose prop.
Foldable prop should be cheaper than VP.
Less take-off power.
Electric motor for tractor could drive 4-bladed prop at peak power.
  • $\begingroup$ What do you want to do with the set of props not optimized for the current flight speed? Let it windmill? Put it into a bay ? Keep it as a non optimised propeller still trying to power the aircraft? Let them acts as airbrakes? (Feathering seems to be excluded as you don't want pitch variability enabled) $\endgroup$
    – Manu H
    Dec 6, 2019 at 11:00
  • $\begingroup$ whatever will be the optimal solution. Putting into a bay / folding would be probably the best one for low speed prop to minimize drag for a high speed one and windmill may work for a cruise prop as it is only for a short time period $\endgroup$ Dec 6, 2019 at 13:48
    $\begingroup$ To stow a propeller while continuing to use the engine you will need a clutch, which is usually a heavy and relatively complicated piece of equipment. $\endgroup$ Dec 6, 2019 at 15:23
    $\begingroup$ I would expect an engine to weight even more than a clutch, but yes, multiple loads on a single engine are not impossible. $\endgroup$ Dec 6, 2019 at 16:32
    $\begingroup$ The best option is a horizontally locked pusher propeller and winch launching. Landing will be in unpowered glide. No deadweight from second engine. $\endgroup$ Dec 21, 2019 at 10:04
This doesn't specifically answer the question in the title, but from the body of your question I would say it's possible, if you had an electric push/pull configuration with a motor in the nose and one in the tail, or at the back of a fuselage pod with booms like a Cessna Skymaster.
The aft facing motor could use simple fixed pitch folding propeller that folds aft and trails in the slipstream when not being driven (popular with motor gliders) and it would be used only for take off and climb, with climb-optimized pitch. In cruise that motor could be shut off and its batteries assigned to the front motor and its blades would fold into a near zero drag trail position. The front motor could have a fixed pitch prop optimized for cruise.
The key issue would still be worst-case climb performance. It would have to be able to make enough thrust on the single cruise pitched prop at the front to climb decently if the back motor failed. Possibly if the front electric motor had some sort of emergency boost feature, where it's torque could be temporarily increased (enough to get its coarse pitched propeller up to red line) for a certain number of minutes without overheating, would be sufficient for single engine safety, with the rear propeller folding back on its own for you.
For single engine performance on the rear motor, you might get away with just a brake for the front propeller to stop it from windmilling if its motor failed. Not as good as feathering, but far less drag than windmilling.
The Voyager aircraft was a push-pull twin with different engines/props.
The front engine is a 130 hp air cooled 240 ci engine.
The rear engine is a 110 hp liquid cooled 200 ci engine.
Both engines turned Hartzell hydraulic constant speed props developed in just 17 days.
The front engine had excellent power-to-weight ratio, but was less efficient. The rear engine was heavier, but was very efficient.
The plan was to operate both engines for takeoff and climb. Then, at altitude, shut down the front engine and just operate off the rear for the duration of the around-the-world flight.
Towards the end of the flight, they had a venting / fuel starvation issue that caused the rear engine to shut down. They restarted the front engine to keep them aloft until they could sort out the fuel delivery problem.
In general, you want variable pitch propellers when the aircraft needs to operate over a wide range of operating points (speed, altitude, and thrust level). This is often simplified in general aviation to takeoff and cruise -- or climb and cruise -- but the operating envelope is more complex than that -- particularly for high altitude aircraft.
