If an F-16 pilot pushes the stick forward hard enough to send the aircraft into negative-G flight, does the jet tend to accentuate the new flightpath, requiring the pilot to counter that, or not?
The F-16 is unstable at low speeds, and stable at higher Mach numbers. It has a flight control computer though, which stabilizes the aircraft using the feedback from pitch rate (so from the view of the pilot an F-16 acts similarly as a stable aircraft). This applies to both positive and negative attitude disturbances, so for both + and - G loads perceived by the pilot.
  • $\begingroup$ Thanks ,this instability translate into the quick response in pitch up and down or only up ,this is my question ?Your answer is accepted. $\endgroup$
    – George Geo
    Nov 30, 2019 at 15:14
    $\begingroup$ The stability of the aircraft depends one the derivatives of state variables (velocities and rates). In a normal flight regime (not near stall) these are continuous functions, so the (in)stability will work "both ways". Here you can learn more about the flight dynamics of the F-16: home.sch.bme.hu/~xtrykyx/diplomaterv/Egyeb/F16Manual.pdf $\endgroup$
    – onodip
    Nov 30, 2019 at 16:33
  • $\begingroup$ Thank you for your time. $\endgroup$
    – George Geo
    Nov 30, 2019 at 16:34
