31
The DHC-8-400 (and possibly other DHC-8 variants) has (or, at least, had in late 2007, according to Appendix G of this AAR) a warning light labelled “TOUCHED RUNWAY”.
The extract of the DHC-8-400’s QRH quoted in Appendix G of the aforementioned AAR mentions this warning light at the end of the landing-gear abnormal-procedures section, and says what to do if the light illuminates, but not what the light actually indicates:
”TOUCHED RUNWAY”
(Warning Light)
  • Do Not Start APU
  • Advice [sic] ATC for Runway Inspection
Note: Continued flight operations require maintenance approval.
The landing gear of a DHC-8-400 (or, indeed, of any aircraft so equipped) routinely touches the runway, and the ramp, and the taxiways, and the hangar floor, all the time during routine operations - indeed, touching the ground (including, but not limited to, the runway) is literally the primary, and very nearly the entire, purpose of landing gear! So what does the “TOUCHED RUNWAY” warning light indicate that is severe enough to warrant possibly grounding the airplane?
51
The light is a tail-strike indicator.
Touched Runway system
The Touched Runway system provides a warning light in the flight compartment. It illuminates when the aft fuselage makes hard contact with the runway on take off or landing. The system consists of a frangible1 switch located at the bottom of the aft fuselage, activating the warning light. The system is powered from the 28 Volt DC right main bus. Once activated, the frangible switch can not be reset but must be replaced by maintenance personnel. Source: Smart Cockpit.
1 frangible /ˈfran(d)ʒɪb(ə)l/, adjective
  • able to be broken into fragments; brittle or fragile. "the frangible skull of an infant"
  • denoting ammunition designed to disintegrate into very small particles on impact. "frangible bullets"
Figure 1. Source: ATSB.au.
Figure 2. Source: ATSB.au.
Links:
  • 26
    $\begingroup$ What you're saying is that the "touched runway" light has nothing to do with the gear. It's a notification that there was a tail strike. $\endgroup$
    – FreeMan
    Nov 30, 2019 at 0:28
  • 7
    $\begingroup$ Correct. The switch is on the underside of the tail. See the update. $\endgroup$
    – Transistor
    Nov 30, 2019 at 11:00
  • 16
    $\begingroup$ The B777 has an EICAS warning message "TAIL STRIKE" that is displayed when a tail strike is detected. Seems like better wording than "touched runway". $\endgroup$ Nov 30, 2019 at 14:24
  • 8
    $\begingroup$ There are a couple of other very obvious indicators of a tail strike in that photo :-D None of which are visible from the cockpit, of course, hence the sensor. $\endgroup$ Nov 30, 2019 at 15:21
  • 11
    $\begingroup$ Judging by the amount of what looks like multiple strikes on that plane I think it would be worth carrying frangible switches in the hold. $\endgroup$
    – Transistor
    Nov 30, 2019 at 18:32
24
To supplement Transistor's answer:
The reason for the light is that tailstrikes are very easy to do on the 400 due to the stretch of the rear fuse with not enough landing gear lengthening to compensate, so they are more limited to the deck angle when landing and taking off than most a/c. This isn't a problem on the other shorter -8s and is mostly unique to the 400.
When you land or take off a 400 you pitch to a certain attitude and avoid pitching any higher (I forget the number - 10 or 15 degrees or something like that) and on landing you control the touchdown by feathering off the power while holding the pitch attitude constant. You don't just go to idle and hold it off hold it off hold it off, pitching ever higher until the mains touch.
It's a bigger problem when landing at one of the lower landing flap settings (-8s don't need to be full flap only for landing and the lower settings are more efficient) which puts the deck angle higher in the first place. Landing at full flap it's not so bad. I know one acquaintance that has bumped the tail on the 400. Not that big a deal.
