Why does the circulation around a centrifugal pump blade tip go from low pressure to high pressure as an effect of the slip caused by the non-uniform velocity distribution (the opposite of a wing tip). The reason stated in my book says that below the blade there is low pressure leading to high velocity and vice versa for the part above the blade. In an airplane, there is vortex at wing ends where air moves from below(high pressure) to above(low pressure) as given in the diagram.
$\begingroup$ Also how less pressure leads to high velocity? Don't tell me to use bernoulli as the flow has vorticity. $\endgroup$ – Deepak Rajpurohit Nov 26 '19 at 12:51
1$\begingroup$ Deepak, your second picture depicts wing tip circulation, which may be a different consideration from evaluation of 2D "circulation" of an airfoil. $\endgroup$ – Robert DiGiovanni Nov 27 '19 at 8:32
I think what's confusing you is that the text book is using the term circulation to describe speed relative to the average airflow, not actual circulation around the blade.
There's still a black arrow pointing outwards on the high pressure side of the blade - no air is travelling inwards.
However if you look at the difference between actual speed and the average speed, it's negative on the high pressure side and positive on the low pressure side.
I don't fully understand the theory, but I think you're supposed to imagine the surface of the aerofoil (or an infinitely thin layer of air next to it) to be circulating, and causing the velocity gradients.
Wikipedia says:
$\begingroup$ I think you do understand it fairly well. Look a nor'easter compared with a hurricane. The circulation in a hurricane is perfectly circular. The faster moving nor'easter has air flowing "up" and over the "top" of it, and a "downwash" behind it. $\endgroup$ – Robert DiGiovanni Nov 27 '19 at 8:37
It is important to visualize the flow into this pump is on an axis perpendicular to the plane of the diagram, flowing towards it. The pump spins "clockwise", there for higher pressure will be on the right side of the blades.
But the centrifugal pump, true to its name, adds energy to the fluid by its rotation, which slings the fluid to the right. The "centrifugal force", really the fluid being propelled to the right 90 degrees from its in flow, drives it at much higher velocity towards the outside of the impeller.
The circulation circled in the diagram seems to be a minor part of the total flow. Though there may be some, the majority of the inflow will be driven towards the outside of the impeller as new fluid is drawn in.
Centrifugal compressor designs are seen in early jets, and are still seen in R/C model jets.
Upon futher inspection, look closely, the circulation is the SAME as a wing. Because the wing is in motion, the circulation may not be fully closed, but the lower pressure areas created by the airfoil as it passes through the air imparts energy to the air in a similar manner as the pump (top lift), as well as the higher pressure area underneath the wing (bottom lift).
The impeller blades are curved oppositely as what we may expect to see in a "wing". Keep in mind this is a rotating device. The outer part of the impeller blade moves much faster.
